- Dec 17, 2010
BM 790 Subrosa.....Does anyone have any experience with one of these?
I had one but ended up selling it because I wasn't a fan of the recurve or AO. But aside from that, it was a great knife -- great size, feel (both in hand and in pocket), and materials. The F&F/build quality was also excellent on mine: blade dead center, absolutely no blade play, nice, early framelock engagement, etc.
In sum, if you don't mind the recurve or AO, I think you'll really like the Subrosa.
Yeah, but can it slice through a meat-filled boot hanging from a rope?
Yeah, but can it slice through a meat-filled boot hanging from a rope?![]()
I also own a 790 and think it's a great knife. On disabling the A/O rollers I would be very careful...without the tension provided by those two rollers there's not a helluva lot holding the blade inside the frame.
I love the blade, it's easier to sharpen than the recurve on the 710, and S30V is very good steel. The Ti slabs are comfy and the knife is very smooth.
It's easy to fix blade play...it uses a hex stop pin adjustable with a T6 Torx driver, and the pivot bolt uses the T10.
I give this knife a big Plus 1, and IMO think it's one of the best BKC models made in 2010.
I have exactly the same problem.I've rotated the stop pin, and tightened the pivot bolt, unfortunately, it seems in my particular knife, that once blade play is tightened out of the pivot, the knife barely opens...
I have one, and I bought one for my girlfriend... Blade steel is fantastic, handle is great, very comfortable, blade shape rocks, i've really only got one minor gripe with mine and that is blade play, mine has a little side to side wiggle whereas my girl's does not... I need to send it in... The ao isn't as smooth as Kershaw in my experience, not that that's a bad thing, they just feel different... I highly recommend the knife, slim profile carries well in the pocket, although the clip on mine doesn't pinch my pocket it just slides over (much like my 630 Skirmish).
I think part of the reason why I haven't sent it in yet is because I do like the knife so much and while I have a pretty good selection of nice blades, I find my edc rotates between the Subrosa, my Spec Bump, Boa and Speedform and I occasionally alternate others in as I see fit, but those 4 blades make up my general edc rotation and being without one for 6 weeks... Well, not sure how I'd handle that lol
Long story short, get one, you won't regret it. I'll probably snag a second one of these days just to have a backup...
Showed this pear what was up:
IMG_0345
