I was actually enjoying the closing with one hand when disengaging the lock and the blade guilotined mi finger...
When I tighten the pivot it is to much and a vertical slight play remains. When I loosen it the vertical blade disappears but the the horizontal play appears.![]()
My 810 has slight play, but it doesn't bother me. In fact, I prefer it a bit loose. As EZ Bake said, you're not risking lock failure. The only thing you're in danger of is a deliciously smooth pivot allowing that slab of M4 to wrecking ball whatever it sees fit. Like your finger.
Benchmade has stated before that their larger Contego and Adamas will have some slight play in them and that is within spec (if you can sort of feel it but not see it, it's within spec). I wouldn't worry about it anyway, considering this lock test:
[video=youtube;V5N1dzv-zKI]http://www.youtube.com/watch?v=V5N1dzv-zKI&feature=c4-overview&list=UUItco_R-gB5lL7Q1ykQT6YA[/video]
For clarity, are we talking about vertical play when opened and locked? Not lateral play, which is adjustable with the pivot?
Correct. The lateral play can be removed, but it is to be expected depending on how loose you keep your pivot. Benchmade said that some slight vertical play is within spec (can sort of feel it but there is nowhere close to enough to see it).
Wild. I've got piles of Axis lock knives going all the way back to the first 710 and I've never seen one with vertical play. It may safe, but it wouldn't be satisfactory. :thumbdn:
My 710s (2 of 4), Adamas, Contego, and 1 minigrip have some lock rock. I remember reading some posts years ago about self adjusting properties of the Axis lock, but I never saw how this worked. It sounds like a good idea, but personally I cannot see how it would be possible.
My experience is that it locks up with a little lock rocks sometimes and zero lock rock other times.I think it depends on how much inertia the blade has when the Axis lock engages. It is possible the lock does not engage the the blade at the exact same position every time.A heavier omega spring would fix this according to my thoughts,but then it would be harder to disengage the lock also.It's kind of like upgrading to heavier(more pounds) recoil spring on a semi auto pistol.....My 710s (2 of 4), Adamas, Contego, and 1 minigrip have some lock rock. I remember reading some posts years ago about self adjusting properties of the Axis lock, but I never saw how this worked. It sounds like a good idea, but personally I cannot see how it would be possible.
