My 710s (2 of 4), Adamas, Contego, and 1 minigrip have some lock rock. I remember reading some posts years ago about self adjusting properties of the Axis lock, but I never saw how this worked. It sounds like a good idea, but personally I cannot see how it would be possible.
There's a slight incline to the axis engagement surface on the blade. As the Axis bar slides forward, it wedges everything in place. I've heard, but not seen myself, that if the liners get dinged up they can interfere with the axis bar sliding all the way forward to lock everything up.
I suppose I could box them up and send them in with details on each one. I might send one in ands see how it goes. The Adamas is the absolute worst of the bunch. I thought maybe the Axis lock was supposed to not touch the far end of the channel (towards the tip) when the blade is locked open.Vertical blade play is something Benchmade has to fix if the choice to send it in is decided. I don't own ANY with this issue; one or two came that way but were fixed to my satisfaction. Blade slop should not be considered 'within spec'.
The axis barbell goes all the way over, no room for wear over time, if that is infact how it was designed to wear in. The Nitrous Strykers I own are some of the most solid liner lock knives I've ever owned. No flex, no sticking, solid lock up and absolutely no slipping.The angle on the liners and/or tang ramp usually adjust for any wear. I've got dozens now, and have had dozens more pass through my hands, and never seen this.![]()
