Benchmade Axis Lock test (done by Benchmade) - VID -
I would like to know what that number translates to. 600 + inch pounds? Meaning 600 lbs per square inch?
I just wanna see them hang 600lbs off the back end and let it swing. A number that means something.
If the lock will hold 100 or 200 or 300 lbs at the lanyard hole, than that means something to me, because I know what the measurement means.
Any one have a translation?
FYI, this knife has no lanyard hole. It is about 3.75" from the pivot to the butt-end of the handle (and the liners extend fully to the edge of the knife under the scales).
Also, the lock never failed. The blade-tang broke (and this is not exactly thin blade-stock). Mine measures at 3.36mm (or .132") at the spine above the pivot and at the flipper.
My full-size Griptilian only measures .115" at the spine. In fact, I'm not even sure that there are more than a handful of Axis-lock folders out there thicker than the 300SN (The Adamas comes to mind).
For such a tiny little knife to take that kind of abuse is impressive enough that it tells me I'll never break the lock or tang (hell, I probably won't break the pocket-clip - it's pretty stout too).
I wonder what the numbers are on a 275 Adamas.... :eek:
Me too!
I know the lock bar and liners on the Adamas are 20% thicker then the standard AXIS models.
I'd be curious to see the numbers on the Contego also. The blade is thick (0.156") CPM-M4 steel. It's hard to tell from just eyeing it but the lock bar and liners look a bit thicker to me then on the Rift which has a (0.114") thick CPM-154 blade .
Have to take them out and have a good look side by side...
Either way I'm sure it would be impressive also...
Me too!
http://www.youtube.com/watch?v=6ZwwLWQk664
looks pretty good. That means you would be able to freely hang about 350lbs off the lanyard point by doing the rough math.
