- Mar 28, 2009
The stop pin position needs to be addressed. I have taken that knife apart and I'm pretty familiar with its function as designed. The stop pin is hex shaped and depending on how it is turned will result in perceived lock rock or up/down play. If the pin is loose or not tightened in the correct position you will run into issues. There should be a dot on the stop pin at the top, when it is adjusted properly. I have spent a fair amount of time adjusting this pin to achieve the best lock up with zero lock rock/play.
