Benchmade Rukus - impressions after a few months of use.
The Rukus lives up to the expectations we have of Benchmade knives: thoughtfully designed, meticulously assembled, first-rate materials, good balance, and strength. The Rukus has all of these characteristics, ESPECIALLY STRENGTH! This knife is solid as a brick. I prefer fixed blades to folders because of their strength, superior balance (when properly designed) and greater user safety. I wanted a large folder for situations when a fixed blade knife was not permitted or would attract unwanted attention. As a stand-in for a fixed blade the Rukus holds up very well.
Though not an assisted opening knife, the action is smooth and easy to operate with either hand. Lock up is decisive and SOLID, with no wobble between blade and handle in any direction even in hard use. There is no way this bad boy is going to accidently close on your fingers, unless you have done something stupid like messed around with the Axis-lock mechanism (so don't do that)! The S30V steel blade takes a very sharp edge with just a few passes over the stone and holds it well. The G10/micarta scales are thick, tough, and handsome, and provide good control even when wet or dirty (essential in any knife intended for rugged outdoor work). The pocket clip works well, allowing the knife to ride low in the pocket or on a belt, but does not interfere very much with a good, comfortable grip. The clip is removable and reversible for left or right carries, but not for tip down carry. (The tip up carry does not bother me, but I know some of you guys don’t like it.) Balance is good, with center of gravity about three centimeters back of the hilt. I like a knife to balance back towards the center of my palm because it allows easier control. If you use your blades more aggressively, you might prefer a center of gravity closer to the blade tip, to facilitate chopping motions. (Personally, if I need to chop, I reach for an axe, not a knife, but hey, that’s just me.)
Still, there are some negatives, in my opinion. This is a bulky, heavy folder. If you want a knife that disappears into your pocket and lets you forget about it until you need it, keep looking; the Rukus is not your best choice. Handle ergonomics are O.K., but the relatively straight, boxy form is inferior to the more contoured, "hand friendly" handles found on Benchmade's Griptilian, Deja Voo, and other (in my opinion) better shaped tools. I do not look forward to using this knife for long periods in cold weather, where those beveled handle corners will be less comfortable than a more contoured handle would be. I also regret Benchmade’s decision to include finger groves in the underside of the handle. While these do enable the user to grip the tool with less chance of it getting away from him or her, it only does so when the fingers are properly lined up in the groves. This will require some users to shift the tool back and forth in their hand before they get maximum purchase. Without these finger groves the user could just grab it and go straight to work.
Bottom line: I like this knife and enjoy using it. I was looking for a large, heavy folder for camping and potentially, outdoor survival and this knife fits the bill nicely. It is a knife you can carry in the most rugged situations with confidence that it will never let you down when the going gets rough. However, it is not well suited (in my opinion) for casual carry or common, light to medium duty use. I would also not take it backpacking: too heavy! For those applicaions less would definitely be more.
Excellent review. I found the Rukus too big for my taste, so settled on the Mini-Rukus as being a bit more portable.
Thanks, Alberta. The smaller Mini-Rukus is a better choice for most users. I do not use my Rukus for EDC (though I have heard of people doing that) and I do not think the Rukus is a good choice for EDC because of its (in my opinion) extreme weight and bulk. I consider the full-size Rukus to be a special, heavy-duty tool suitable for unusual, specialized applications. It might also be illegle to carry the full-sized Rukus in some jurisdictions. Interested knifers should check applicable law before choosing this or any similiar tool.
I used the Rukus for a week in a passaround and concur with all of your points. I ended up getting a Spyderco Manix instead of the Rukus because I liked the ergos and rear grip hump on the Spyderco for better grip security, though both had equally excellent blade geometry for such HD beasts. The blade on the Rukus opens and closes fast and smooth due to the axis lock, and aside from needing deeper pockets than normal (not in the monetary sense) I thought it carried very well, but it's huge weight might bother some. Overall I was very impressed with the Rukus and would have bought it had the Spyderco Manix not come along and made me like it a bit better. For a super heavy duty large folder you could do a lot worse than the Rukus.
Mike
I don't have one but am contemplating it. FWIW, I thought the Rukus was tip-up only carry?
They are, straight from BM's website.
"Clip: Black, Reversible, Tip-Up"
Right you are, Splat and Bear Claw. Thank you for catching my error. I have corrected the text of my review.
Gunmike1: You chose wisely. I have not handled the Spyderco Manix, but the pictures and specs (not to mention the Spyderco pedagree) make this look like an excellent choice for a large folder, with less bulk and weight than the Rukus. PS: On the Spyderico web site they are listing the Manix as discontinued (though still available for sale). Anyone considering this knife should make up their minds quickly, or forever hold their peace.
Keep `em sharp, people!
Thanks for the great write up. I really want to get a mini Rukus when funds allow. The full size is just too big for me to EDC, bot practically and legally.
Thanks again for the review. Assuming I get the mini Rukus, it'll be my first BM.
I decided on a mini Rukus as my edc. I actually ended up w/ two because I came across a spring assisted limited edition version that I couldn't pass up. I love it, it moved to the front of the line as my EDC in a hurry. It's been a few months now and I don't see that changing any time soon.
The only "complaint" I have heard about it is that it looks "too aggressive" for some people. As a knife person I don't see it, but to each his own.
Monk3yfist: An assisted opening Mini Rukus? Wow, I would not have been able to pass that up either. I'm jealous, dude! I understand what you mean about the aggressive appearance of the Rukus. Like you, when I see it, I see a heavy-duty tool, not a weapon, but, oh well. Truth be told, while I do not happen to own or carry knives as weapons (no bash on those who do, just my personal preference) if I did, I would not choose the Rukus as a fighting knife. The Rukus' ergonomics are poor for a fast grab and quick, dexterous defense. There are better choices for those who need a knife as a weapon.
I happen to be one of the people who EDC the Rukus. I love it and even though it is seven ounces, I have to reach down to make sure it is still in my pocket. I love the knife it's built like a tank.
I recently started using my mini-Rukus for EDC. I've had it for almost a year and never really carried it. Not sure why but now it has been a great hard-use folder the feels like it can tackle anything.
Ahhh....the Rukus. One of my all-time favorite knives. Full size version and yes, it gets alot of pocket time and yet never feels "full size". Pictured here on top of one of my other favorite toys. Enjoy.
Thanks for the photo, Jonny16. They make a beautiful couple. You are well equipped to take care of you and yours in the roughest of circumstances!
I had the Rukus and thought it was a fantastic designed and built knife. Sold it before I was aware of the mini Rukus. I prefer pocket carry and felt that omega springs did not have enough force for that heavy blade and did not trust closed retention in my pocket. I believe omega springs were same size as ones in my BM HK14210 which has a blade about 1/3 the size.
I was able to pencil sharpen over 20 1.5 in poplar saplings for shelter poles ( leaving behind standing fuzz sticks) before I lost the edge. True folding sword.
At the moment this is my favorite folding knife. I've had one for a few years now and recently purchased another with a combo edge. As the op said it definitely has some weight which I like a lot. Action is smooth and only gets smoother after use. Finger grooves happen to fit me perfectly in various grips. If your looking for a larger heavy use folder, I would definitely consider this.
Edit: Although you'd probably want to hold it to see how the grip fits you.
Mine is a keeper, too, despite it's being less than razor sharp out of the box. It fits my hand nicely, but I can see how some wouldn't care for the fit - or size. Do yourself a favor, if you are considering this knife, and try one in person first - or get the mini-Rukus. Heck, I am getting a mini, too - and soon. I guess you may as well go ahead and start with the mini - chances are you'll get one eventually. For scale, below is my 610 Rukus with my recent Kershaw JYDII Ti/SG-2 purchase:
That JYDII is a large knife... Like I said, my Rukus is a keeper - a 'bushcraft' folder. I would definitely 'test drive' one for hand fit, if possible, before ordering one sight unseen.
Stainz
Stainz wrote, "my Rukus is a keeper - a 'bushcraft' folder. I would definitely 'test drive' one for hand fit, if possible, before ordering one sight unseen."
Dead on, Stainz.
Actually, everyone should test drive a knife they might be interested in using before actually laying out the cash. I've learned my lesson and often wound up selling knives that I thought would be comfortable based on prior purchases but turned out not to be. I love my Mini Rukus.
