I have a Spyderco tenacious, resilience, and 2 enduras.. Awesome knives. There very light, comfortable in your hand. There shaving sharp. And for $33 or $44 bucks. $60-70 for the endura4. I also have had the bench made 550 and 551. Cpm154 steel is a very good steel keeps sharp along time, depending on your usage. There all high performance blades. There is a line of heavy duty folders made from pretty much the same steel. The line is called bad blood..I have all 3 folders and the fire spitter is by far my favorite. Is also 9.5oz. It's a BIG knife. I also have had a pelican brand light since2005 and have not had to change. The bulb... It's a good bright full size light. Great for ccw, light/knife.and it's tuff. I also have 4 surrefires and there great also. Your choice of Knife/light combo for your price range is rather large. I have had over 15 different models of Kerahaws. You have a lot of research to do. It has taken me 8 years and a lot of r&d. There all solid brands..
Just go to his website:
www.kershawguy.com
It will be under the "Kershaw New" section.
Anyways, my two pennies would be to get a slightly higher end knife and a good little flashlight(doesn't need to be super fancy) for EDC.
A good medium priced knife would give you an EDC that you can use for years. A slightly higher end knife will give you something with a better steel that needs sharpened less and will likely require less maintenance and will in the end, last longer.
There are several awesome EDC knives out there in your range but for this I would pick Spyderco. It feels like you get more for your money in the way of steel, materials, design, and fit and finish.
So here's a few Spyderco Knives I would recommend:
Spyderco Para 2
Spyderco Caly 3 or 3.5(I would go for the CF/ZDP)
Spyderco Stretch(I would go Green/ZDP)
As for some Kershaw/ZT knives to check out...
I would pick up a ZT Blem 0350 (it's $85 for standard or $95 for Stonewashed or Tiger Striped). If you don't like the assist, you can remove it and it makes a great manual flipper. This is great if you want a beefy knife with a good steel that will take anything you throw at it.
I'd also take a look at the Kershaw Speedform 2 - G-10 handles with a great Elmax blade for around $75, which for what you get I believe is a great value.
For all around EDC I would look into the Spyderco knives and possibly the Speedform. Spyderco knives just make a great EDC because even if the blade is thinner it can take a lot, the full flat grind makes them wicked slicers, and all around they can handle anything you ask of them, hard tasks, light tasks, medium tasks, they just do a good job all around.
So I would look into some of the suggestions and maybe pick up a 4Sevens Mini AA for your light, it's small but powerful and as bright as you'll likely need for daily EDC. Several modes. I've owned several lights and this one is my favorite little EDC light.
Maybe try for a Spyderco Para 2 or Sage 1(Carbon Fiber) or 3(if you like blue, this one is extremely smooth and I love the lock) and the Mini AA. Would make a great pair up.
