Gavin,
You had noted less than $400. and with the coupon it will be well below that point.
Two Speed Variable Micro Mill/ Drill Machine
Precision milling and drilling at a price you can afford.
Capacities: drill 25/64'', end mill 25/64'', face mill 3/4''
Dual speed range: 100-1000 RPM low, 100-2000 RPM high
Designed for use with steel, brass, aluminum, plastic and wood
Cast iron base and main post with steel gear housing for rigidity
Machined and ground ways for effortless table and mill head movement
Dial adjustments for lead screws calibrated in thousandths of an inch
Motor: 120V, 60 Hz, 1/5 HP; Max. travel: x-9'', y-4'', z-8-1/2''; Chuck to table clearance: 7-3/4''; Table size: 9-3/8'' x 5-3/8''; Table slot: 1/2'' x 3/8''; Throat depth: 5-1/2''; Swing: 11''; Spindle stroke: 1-3/16''; Spindle taper: MT2; Base size: 10-1/8'' x 9-3/8''
Shipping weight: 103 lbs.
ITEM 47158-6VGA
$319.99
