ExtremAddiction
- Apr 12, 2013
Light , Very strong , can be finished in many different ways , wont rust .
Titanium has disadvantages though too. Such as screws that thread directly into Ti are generally more likely to strip the threads. Also Ti as a lockface tends to stick to the opposite lockface on the tang of the blade. Means a Titanium lockface will wear away faster. Consequentially they have titanium framelocks with steel lockbar tabs as well.
DuctilityDoesn’t rust, light weight, and, I’m not sure what the technical term is, but it works very well as a spring (so it’s ideal for frame locks).
The neat thing about threading Titanium is if you break a tap, you can dissolve it with battery acid. Don’t try that with steel or Aluminum.titanium hard material to work with , especially treading it quite difficult and tools expensive , most likely tread wasnt made properly to begin with .
The most important use for Ti. Is it will hold spring tension when bent making it particularly suitable for framelocks.sorry im a newbie.
What is the benefit of having framelocks made with titanium? Is there any benefit other than weight reduction?
Thanks
