Ben's Beads Auction is Here!
"Kevroo, not to give away trade secrets, but are you turning those on a wood lathe and then drilling the hole after wards or do you have some way to chuck up a smaller diameter hole and then turn the bead?
BTW, thanks for doing this!"
Swo, I probably need to re-examine and rethink my method in making these. If you Google search "make wood beads without a lathe" a video will pop up. That's where I got the idea, the method I use is like this but more in depth. Aside from the liner's & burlap, I purchased some wood pen blanks from bell forest. I hand cut the pen blanks, anywhere from 1/8-3/8" at a time. The liners & burlap are also typically hand cut about an inch square. Once I have numerous pieces cut, I rough sand all edges with a 60 grit sandpaper ( it's my understanding that will help the epoxy bond strength). After sanding, I check all sides against a light to make sure there's no gap's or large spaces in between the layers. I then brush everything with a wire brush followed by a cloth wipe down (getting rid of all the dust/debris). From here I mix up the epoxy, glue, and let sit clamped anywhere from 1 to 2 days. Afterwards, I go to my little belt sander to kind of square it up, get rid of the excess edges (liner mostly). I use a little square to find the center from which then I drill out with a 1/4" bit in my drill press. Once all this is done, I take a 1/4" brass bolt and place it through the block with washers on each side. I run a nut down and snug it up and chuck it in my electric drill. With the drill on low speed I use a rough grit paper in my belt sander, slowly working my way up to a 600 grit paper. From there I usually sit inside the house and hand sand with these little padded pen sanding blocks (sometimes up to a 12,000 grit). Once all is finished, I've been applying ren-wax to give it a little more shine. That's it more or less.
I know that I could find some easier ways to cut down on the time, but I enjoy working with my hands. I'd love to try something with a lathe, finances & space are my largest obstacles. I'd consider myself a beginner and am open to any input or idea's. And Thank you for participating!
ALSO, A big thank you to Andy & crew for letting us post here to raise some cash for a well deserving person.
Kev
Bush.Hacker, bidding against yourself to get some action going. That's so awesome! :)
Lot 3: $60
Wow! Just wow! The good karma choo-choo train has pulled into the station.
Thank you all very much!
I've got the warm fuzzies!
Thanks everyone!
Well, that was fun to watch. My hat's off for all you gentlemen
