- Dec 28, 2003
Well, I worked out a deal to get Danny's bent 25" gelbu, and with Khukuri Monster's excellent advice I worked on it today and was very pleased with the results.
I chocked it up in a 7" Wilton woodworking vise, and used hardwood dowels in place of the steel rods khuk monster recommended, and then tightened it up _very_ carefully. I half-expected the thing to snap, and at one point had it at least 1" out of alignment in the direction opposite the bend. I'm sure I probably could have gone several inches before anything happened, but I didn't want to find out as I know I was putting a lot of stress on the long blade.
I tightened it in the worse area of the bend, and then loosened the vise and rolled the blade both backwards and forwards along the dowels, and then repeated the process each time.
The bottom line is that the blade is over 2" deep at the bent area, and because of both the distal taper, and the taper from the spine to the edge, it bent in different ways at the time of the damage.
My main concern was getting the cutting edge straight, and that worked out perfectly. In one spot the spine is still maybe a sixteenth out of alignment, but I can't tweak that so easily without also changing other parts of the blade, so I'm going to resist my perfectionist nature and leave it the hell alone. The cutting edge is straight now, as well as most of the blade itself in that area, and that's what matters as far as using the knife.
I think the damage happened because the blade is not really that sharp. No kidding, it is a tribute to Danny's second swing that he was able to get through that bamboo with this edge IMO. The slightly off center first cut combined with the dull edge turned the knife and caused the damage. At least that's what I think, I _could_ be wrong!
Here's some of my typically awful pics. The first two show the setup with the vise that I probably repeated in different areas a dozen times, the third shows the knife laying flat on my anvil, so that you can see the blade is straight now, and the last fuzzy one is the blade held straight out, with the formerly bent part of the blade hilighted.
My only question now, is how that bending and rebending back will affect the integrity of the blade. Hopefully it can still be used safely for some cutting tasks.
Next I have to use a burnisher on the blade, as the bend put a little ding in the edge that has to be rolled out, and then I'm going to sharpen the whole thing the way Yvsa showed me at the SWKK with my Cherokee Rose, with a DMT sharpener. Should be a nice big razor when I'm finished.
This is a nice knife, and I'm glad this worked out for everybody.
Regards,
Norm
Regards,
Norm
