- Oct 18, 2001
I use this stuff:
http://www.radioshack.com/product.asp?catalog%5Fname=CTLG&product%5Fid=276-1535
But unless you have the right equipment setup, you'll be in for a nice mess.
First time khukuri etchers should do this:
1. Thoroughly clean the blade with hot soapy water
2. Thoroughly wipe the blade clean with Windex
3. Heat some vinegar in the microwave (in a throw-away tupperware) to just barely above "hot tap water" temperature (around 120 degrees if you've got a thermometer). Add a few drops of liquid soap to the vinegar.
4. With the blade on its side on a ratty ole towel (or cloth), dip a cotton ball in the hot vinegar and start rubbing the blade lengthwise with it, keeping the cotton ball well-soaked.
5. Repeat on the other side.
6. This will take more time than a FeCl etch (using PCB). But it makes a nicer etch, in the opinion of certain bladesmiths. In other words, you may need to keep rubbing for while...don't give up on it...don't expect immediate results. Put on some relaxing music....
7. When you've got it where you want it, you'll want to neutralize and remove the surface oxides. Rinse it first with Windex (or baking soda & water). Then load up a cloth with Flitz or Simichrome and lightly buff the blade by hand.
8. Last step is to clean it completely.
Final note:
This is going to stink - bad. :barf: Do it somewhere ventilated, or suffer the consequences.
Final note:
