I just noticed (after the 600 grit step of hand finishing
) that I have a slight bend in the tip of a blade. It is about 3/8" of the tip and the bend is slight but noticeable if you are looking for it. It is a personal blade, so I can live with it I guess, though it will haunt me forever!
This is an O1 blade that I did HT with a torch and ATF with a 450 degree temper (oven thermostat picked a crappy time to stick...whole 'nuther story). It is about .035" thick at the bend point. My best estimate of the bend point is about .20" back from the tip. The offset is about .02".
If I were to guess at the quality of my home HT, I would guess slightly under heated during the hardening stage. It took me 3 tries (heating a little more each time then dunking) before I got a file to skate, and my soak time would be maybe 2 minutes.
What do you think my chances are of straightening it without breaking it off?
It is dang hard to just chalk a blade up to learning when you have so many hours into one and so few under your belt as I do...
