- Sep 5, 2002
which other lock types don't require you to have your fingers/thumb in the way of the blade closing when disengaging the lock? I guess autos with a button would apply. what else?
Spyderco's Meerkat. There are others but that comes to mind first. Rotate one scale away from the other and the blade unlocks. I have no idea how it works.ohmyheckinslc said:Phantom Lock?
Artfully Martial said:With a lot of practice and an easy action, you can flick liner and framelocks (collectively crosslocks) closed too. But yeah, your fingers are definitely in the way momentarily. If you dare try this trick, you simply push the liner across whilst flicking the blade closed and get your finger out of the way quickly. It takes flawless timing on all three movements...but with a little practice, completely doable. You can of course see the obvious danger involved...
There's a good 95% chance of getting cut your first several tries here, so, you've been warned...
I don't see how anyone would need to put their fingers in the blade's path while closing a lock-back.hardheart said:I'd say lockbacks do pput your fingers in the way. With a decent spring, you need to grip the knife to release the lock. And there's some liner locks with mechanisms to keep your fingers out of the way. The new Gerber firefighter model has one, and I think a CRKT (Convergence?) does too.
I put my fingers in the way every time I close a lock back. I'm curious as to how you close them.allenC said:I don't see how anyone would need to put their fingers in the blade's path while closing a lock-back.![]()
The same way I close a slip-joint except that I use a finger or thumb to press the lock-release.J85909266 said:I put my fingers in the way every time I close a lock back. I'm curious as to how you close them.
And how is it you manage to put your thumb on the lock without putting your fingers in the way of the blade?allenC said:The same way I close a slip-joint except that I use a finger or thumb to press the lock-release.
