- Feb 2, 2005
Great choices, all. If I were going for a Caly 3, I'd probably want the G10/VG10 version. That version of the knife is a little thicker than the CF version and the G10 scales are much grippier. If this is going to be used for SD, those may be points to consider.
A couple of other choices would be an Al Mar Nomad or mini-SERE. Both come in right around 3" blade length with G10 scales, well made liner locks, VG10 blade steel, and light weight. The mini-SERE clip mounts on the butt of the knife, so it carries about as low as you can get. The Nomad is a fine slicer with it's flat ground blade. I suspect that either would work for SD if necessary, although neither is a dedicated SD knife. F&F is top notch on both of the ones I have.
