Want a drill press?Hey KV
I live in Southbury too !!
Bill
I have been looking at this too. What accessories did you get with it? Did you go with the DRO? I felt like the expense of the DRO was way more than a DIY solution but if it is all done I dont have to mess with it.I just made the same decision a couple months ago. I wanted a drill press that didn't wander, didn't have stupid run out but had variable speed.
Precision Matthews bench top mill pm25 hands down one of the best value machines I have ever purchased. I wish I had known about them years ago.
https://www.precisionmatthews.com/shop/pm-25mv/
This is nothing like a Grizzly, Jet, Delta or HF mini mill even though they maybe somewhat similar in appearance.
I got the stand the optional DRO - which I really haven't used. Nothing has come up to use it yet. I have a full sized mill with DRO also so it probably won't get used much. It has a built in Z DRO which I have used several times for drilling or light milling to depth and that is probably all I really wanted. I would not get the optional DRO if I did it over. I also got the "accurate" keyless chuck and it's worth it. You will need to use a spanner wrench to tighten it so the key is replaced by a spanner wrench. Still it's slightly faster than a key and the chuck is quite nice.
Think of the Milling Machine as a VERTICAL Lathe...The Lathe works primarily on Round Stock rotating in the Chuck you feed your Tooling into the Material on the Horizontal Plane The tooling is stationary and the Stock Revolves...The Mill has the Stock Stationary on the X-Y axis and the Tooling Rotates in the Quill and is Fed Downward as it Rotates which allows you to Machine Parts that are Square or Rectangular...Basically the Same Principle of material removal of different shaped stock.Thanks! I dont have any of the equipment and have been putting things in and out of my cart for a while. Debating about the stand but it may make sense. Have the r-8 collet set (does the ultra precision make that much difference?), the clamping set and the basic vise.
I have done some machining in the past but mostly on lathes. The mill world is a new thing to me.
I have one of the old models as shown on FB but a bench model. It's an Atlas. Real tank in great shape with 0 slop in the chuck. Two people or a dolly to move it. Easy to work on and change speeds/pulleys. I rescued it out an old house demo. Probably from the '40's.
I'm downsizing to move and don't really need it anymore
If anybody is within driving distance of west central CT and wants to load it, its yours.--KV
Gone to a neighbor. Sorry.--KVIs the Atlas still available?
No problem! Anything else you're looking to sell or get rid of? Just started and looking to expand the shop.Gone to a neighbor. Sorry.--KV
