So what would all of you "no coaters" do on a week long expedition in a high moisture environment and a high carbon blade?
Wipe it off.
Wipe it off.
How often in a high humidity environment?
We "blue" them with lemon.As often as one wants. People did use carbon steel blades in high humidity environments for more than a week at a time (e.g., machetes) for quite a while before stainless came into play around 100 years ago.
They seemed to do OK.
Im going to have to disagree with you. I live in a very humid area, so the coating does help me, and I like the look of quality coatings like dlc as they wear a bit.
Not all metals benefit from a nitride-type of coating. Stainless steel will actually become less resistant to corrosion if it is nitride coated. Free chromium that acts as a passivation layer will bond with nitrogen to form chromium nitride(CrN).
Black oxide is a surface treatment, not a coating. Basically it's a black controlled rust. What they typically use to finish a rifle barrel. Whatever part is lowered into a salt type bath solution that gives the surface a black finish.What is black oxide coating?
