So which of the knives you own (since it looks like you own most of the steel I’m looking at) holds a sharp edge the longest? Which is your favorite and why? Thanks
Ah that sucks man. I know the early reports of maxamet had some issues. I guess it's just the territory for near 70 hrc.I was cutting some conveyor belt at work with my maxamet Manix and it snapped. I was pulling it back out of the cut I just made because it was stuck. I twisted a little bit and it ended up snapping. I had done this job hundreds of other times with my other knives and they fared just fine.
Yeah either rex 45 or k390 imo has the best characteristics. Once magnacut comes into the market let's see if the production companies can pump out magnacut at ~65 HRC to match the properties of rex 45.I had the idea that rex45 has the best combination of edge holding and toughness but in general toughness and edge holding are opposites and you can’t have both- pick which one you want the most.
I haven't given my GB2 with M4 any special treatment, and it shows only a few tiny blemishes after 8 or 9 months of regular use in the kitchen and around the house mainly. I just rinse it off and dry it. A few swipes on the DMT keeps it hair popping sharp.There a lot of premium steels that excel at edge retention but lack in toughness (durability/freedom from fracture/breaking).
However, M4 and Elmax both get high marks for edge retention and toughness w/the nod going to Elmax for ease of sharpening and corrosion resistance.
I don't believe that you can go wrong w/either of these steels but M4 will require a bit more care/attention than Elmax will.
Both are pretty widely available among many brands and types of knives (especially those offered by Spyderco in M4 and ZT in Elmax) and cost less than other premium steels that lack a balance in the 4 main qualities mentioned.
See: BHQ's Best Knife Steel Guide for further information.
I like the Lynch clip because it offsets around the lanyard hole. Not that I really use the lanyard hole, but my brain doesn’t like it being covered. Some cool color options on the LynchNW website, and Casey is a good dude from my experience and from every account I’ve heard. If you have the maxamet, but like lighter weight, you can swap that blade into a LW. I did this to my LW and there are no issues.Any thoughts on the mxg gear deep carry for pm3? Any other recommendations?
Is it possible to buy the blades of the LW? or do I have to buy the entire knife? ThanksI like the Lynch clip because it offsets around the lanyard hole. Not that I really use the lanyard hole, but my brain doesn’t like it being covered. Some cool color options on the LynchNW website, and Casey is a good dude from my experience and from every account I’ve heard. If you have the maxamet, but like lighter weight, you can swap that blade into a LW. I did this to my LW and there are no issues.
I wish people would stop recommending these "best knife steel guides". For example S110V 6/10 for corrosion resistance???There a lot of premium steels that excel at edge retention but lack in toughness (durability/freedom from fracture/breaking).
I totally wasn’t clear. Although blades may be available through Spyderco or custom makers, it’s the other way around. You would need the frame of the LW to install the blade from the G10 version. So, yes. You would need to buy a LW. You could probably look for a cheap user on the exchange.Is it possible to buy the blades of the LW? or do I have to buy the entire knife? Thanks
