I have both of these knives and would recommend either one. The only drawback is the kraton handle that is found on both -- it's grippy but it wears off quite easily.That is a pretty vague answer to "Best for what?" considering Cold Steel's vast line of very different blades.
But for the sake of an answer try the SRK or Recon Scout. Both can easily be carried [the SRK being smaller and lighter has an edge here] and they are both as tough as any knife on the market. They are both versatile and can handle big and little jobs well and they have fantastic edges that hold up even after prolonged use. If things go wrong while you are in the field either of these will function in a survival role and never let you down...give the SRK or Recon Scout a try and you will not regret it.
I've had a couple of Recon 1's and the spear point is my favorite CS folder. Big, strong aus8 blade and a super-solid lock-up. Out of the box, it shaved my arm hair. You can't go wrong with this 4 inch bad-boy!Recon 1 spearpoint
