Who is "Dave Grossman?"
Are you aware that to "decimate" means to kill every tenth man? It may not mean what you think it means.
Do as you will. You'll be well prepared when the big roast beef attack someday comes.
Do you mean to say that Japanese Kendo practitioners are preparing for an attack by rolled tatami mats?
You come in with 31 posts and tell us what we do is not simulation.
If you can suggest a better way to test the capacity of a knife, please do so. If you can't.....
Why, did I say that? Put words in your own mouth, not mine.
Kendoka learn to strike and defend by hitting with a shinai.
In Iaido, we do perform a cutting test, which is not a test of the blade at all, but a test of the practitioner. The sword is not judged by the cleaness or angle of the cut, but rather the practitioner's skill and technique is reflected in the cut. Whether tatami or bamboo is before the practitioner is irrelevant; the cut is the same, and it is not the sword which determines the success of the cut.
Miyamoto Musashi was an ancient practitioner who became one of the most famed swordsmen who ever lived. His writings and thoughts are still taught today, in Book of Five Rings. Musashi became so adept at killing with his sword that he determined he would no longer use a metal sword, as it no longer presented a challenge to him. He became known for his use of a bokken, or wooden sword, instead. You may safely assume that a wooden sword would do considerably less damage to your roast beef than a live blade; never the less, Musashi continued to prove that the blade wasn't the determining factor, but rather, the user.
I would be happy to tell you with one post, or a thousand, that you'll learn nothing from slashing away at kitchen reject meat. You really believe that this knife or that will be the determining factor in a fight? Hardly. Emerson knives were never intended for shaving, and were never intended to slice through bone like a laser. They are meant to be tough knives that hold up to abuse and use, and in my experience, they certainly do. I've taken them into some of the worst hell-holes on the planet, and I continue to visit those locations on a regular and consistent basis. I've never had one of Emerson's knives let me down, which is why I use them. I also use other knives, but I'm confident in the Emersons I own.
What I don't do is slice up bits of kitchen meat wrapped in tee shirts. It's a ridiculous idea. If it makes you happy, however, then have at it. Kick some boards in the back yard and break them too, if it gives you confidence. Whatever floats your boat.
When it is time to take the knife you choose into combat, be aware that you'll get bloody, it will be painful and slippery, and the result won't be a function of which knife cut the deepest into your tee shirt-wrapped dinner. It will be the one you most effectively wield in the space of the very few seconds that the encounter lasts. Your knife which cut so effortlessly through polyester and beef will encounter bone, wrist watches, boots, ribs, and vertebrae. It will deflect, it will slip in your hand. It may chip. It will lodge between ribs and stick fast. The last thing on your mind will be your cut-up dinner. Never the less, if it makes you happy today, if it gives you that extra spring in your step, then by all means, slice up that pot roast to your heart's content. Just don't forget to put it back in the refrigerator before your wife finds out.
When you cut your roast beef, you've not tested the "capacity" of the knife any more than you've tested the effectiveness of a firearm by shooting a block of gelatin or a goat. You've seen one cut in one place that means very little. One might say one is testing the capacity of a pen to write a novel by scribbling on a piece of paper, but it just isn't so. Don't blame the pen, don't blame the firearm, and don't blame the knife. A poor carpenter blames his tools; the cutting you achieve with your knife is a function of the maintenance you put into the knife, and your technique in using it. Cutting roast beef with your knife has about as much bearing on "combativeness" or "capacity" as do torture tests on firearms. These tell you nothing, but if they help you sleep better at night, then enjoy the entertainment.
The test of the "capacity" of the knife is found in the mind of the user. "Capacity" is a nonsensical word with respect to the knife; a better word is "utility," and this is very much a function of the user. A firearm is useless without a marksman to fire it, and a knife is useless without a hand to guide it. A .22LR chambering is considerably more deadly when it is used accurately than a 7.62 round that is not. Firing both into meat or gelatin won't tell you that, and neither will putting rounds on paper. Actual application will make it crystal clear, however, in a meaningful way. This you can't do with your firearm or your knife, and so you train, train, and train. You will learn of your success the first day you are called upon to employ that knife, and I would that you never need to do so.
I can tell you a better way, but it means learning to win without fighting, and it means learning that when you use that weapon, you've just lost. Until you understand that thoroughly, you won't understand the foolishness of beating up dead beef wrapped in summer clothes, and nobody can tell you a better way. You'll be content to believe what you believe, and you'll probably go on hacking away at your dinner until it's either ruined or you're pleased with yourself for having finally killed it. Do as seems you fit, and best of luck in your battle against roast beef. Lord knows they're a growing threat in this country, today.
Are you stupid or something?
I typed slow so you will understand.
This thread is not about technique or winning a fight it is about how effective a knife is in cutting meat. whether you agree with that or not, that is what the thread is about.
What is the best blade style Emerson makes for combative purposes?
Gentlemen...Gentlemen....
EEEEEEEEEEEEEEEZZZZZZZZZZZZZZZZZZZZ...
Back to the subject:
If you can get our hands on one, the Emerson Persian is THE perfect little assassin's tool and is as suitable for defense as offense.
The Persian's Yin to the Karambit's Yang, where the claw shape of the Karambit is best for piercing and tearing, the "scimitar" shape of the Persian also pierces with it's needle point but the inherent slicing action of the blade, even when simply thrusting directly forward, is unmatched.
I love my Commander, but my Persian is my favorite and the last knife I would ever give up.
As far as SD goes...have you considered the Emerson dagger? The double edged blade can make it (potentially) doubly effective for SD.
So although your CS scimitar our performed your Commander it's still a "crappy little CS Scimitar" !? First of all the Scimitar isn't "little" . I've got 2 Scimitars as well as the Commander and the blades are all 4" long.
Secondly ,your own experiment revealed the Scimitar isn't "crappy" at all. You probably paid at least twice as much [as I did] for your Commander as you did for your Scimitar. So I guess in your world the Commander, which performed poorly, is still a knife to be respected ,while the Scimitar, which performed well, is still a knife to be disdained.
Something expensive is good,something affordable is crap, regardless of the evidence to the contrary.
True....I just feel the handle quality of the schimitar to be very low quality. That fully serrated 4" VG10 blade is outstanding.
Looks like my recommendation got buried in the shouting match... upgraded Schimitar = Talwar.
Laminate steel, strong rocker lock, Titanium frame/bolsters, G10 handle scales, wave opening, and a stainless steel pommel.
^Just trying to make a relevant suggestion to the OP based on his good experience with a budget blade of very similar dimesions.
