- Mar 29, 2007
I've seen only a few uses for serrated edges, and a lot of bad choices for them
I don't even use them on steak and bread knives, as they simply aren't needed on a properly sharp knife for those uses. (though, the shallow scallops on a carving knife bear as much relation to modern "tactical" serrations as a moose to a walrus)
So, serrations, why have them?
boats are one primary place you MAY want to have serrations, and even then, you want 2-3 inches of them. Personally, The few times I've had to cut cordage fast or else something Bad will happen, I've used a 7 inch fixed blade and just chopped it. (When we lived on a boat I hadn't started making yet and my primary deck knife was my old SOG government)
rescue uses are the only other place I really see it- cutting straps and lines rapidly, be it aircraft, rock climbing, or EMT/SAR type work.
Now, if you need this, go for it, otherwise- well, why bother?
I'm not a huge fan of the idea of taking off into the bush with a folding knife of any type, but I realize it's perfectly workable if you practice bushcraft in keeping with your tools. But if I had the option, for the weight and the size I'd take a pocketable small wharncliffe fixed blade over a folder.
If I was crazy enough to make folders, the one I'd make would have a pen, good tweezers, a thataway compass, flint rod (all of these in the handle scales) and two locking blades. - a 4.25 inch locking drop point or maybe sheep's foot in carbon and a good stainless 4.25 inch saw blade (in the same pattern as the larger victorinox saw blade, but an inch longer)
