I'm a retired FF/Paramedic and have broken more than a few auto windows, both in training and in extrications...
The tempered glass that makes up the vehicle's side/rear windows is easily broken by any GBD (Glass Breaking Device), be it a punch (Res-Q-Me), reinforced Tanto blade knife, and even a MT Scarab GBD. Those auto windows will shatter into many small cubes w/o large and sharp edges.
It doesn't take much force and a sharp *tap* should do it if using an able knife tip.
The Windshield isn't tempered glass and won't break the same. They are laminated Safety Glass and will resist shattering into cubes like the side/rear windows, due to a clear tacky resin between the plates.
To get access through windshields, usually a hole is punched in the upper corner and a saw is used to cut the windshield around the upper and side perimeters. There's lots of *new* and *improved* devices out there but many Departments use something like this: https://www.rescuetoolman.com/Quik_Kut_Vehicle_Glass_Tool_p/sku-art50012.htm
Be aware that if all the airbags haven't deployed prior to a forced entry into a wrecked vehicle, they can/will at any time. The forces in them can severely injure folks, especially someone leaning in through a side window and catching it on the side of their head. Even disconnecting the battery prior to entry can still leave sufficient charge in the capacitors of the Airbag system to fire them for a time afterwards.
Finally, GBD's also are not made to safely break plate glass (think house windows) either, especially for the general public. Good way to cut arteries and tendons. Use a high tech rock of sufficient caliber...
