How is the Spyderco Double Stuff?
Thank you. Do you have a recommendation for a pocket diamond stone?Fantastic for touch ups, but won't repair chips. Get a pocket diamond stone as well if you need that.
Do you think they are both necessary? Would the Diafold be sufficient by itself?I use the DMT dia-fold ones. XC/C or C/F depending on what you expect to be able to do with it. But one of those plus a doublestuff is what I keep in my camping gear.
The Work Sharp looks phenomenal- perhaps slightly more versatile than the Diafold?May not be for everyone but I have a couple for field use and like them alot for that use.
Check out the Work Sharp Field Shapener ... they have a couple models now but gives you a couple different diamond plates with a guide for angle and a ceramic rod with different grits as its turned. and even a small leather strip for a strop.
The new model has more features and with a small accessory kit for it gives you 4 Diamond plates of varying courseness ... with a 17 or 20 degree guide and still offers the ceramic and a leather strop on a plate.
I like them alot for a field touch up and could be used for more with the newer model.
Ordered. Looks like a great tool!The worksharp is awesome. It allows some refinement of the edge. You get two diamond plates, a ceramic rod and built in strop. The plates are removable too.
I'd go for the C/FDo you think they are both necessary? Would the Diafold be sufficient by itself?
The Diafold C/F will probably make it into my kit soon enough. My sharpening equipment as is costs about twice as much as my most expensive knife.I'd go for the C/F
