I use the DMT credit card sharpeners. I'm not sure how many I have but I use them at home, work, hunting, hiking, and camping. They are small enough for most kits/bags.
Please don't support dealers that sell counterfeits.I have had one of those DMT double sided folding sharpeners for over 10 years and are easy to carry and are long enough to put a edge on my knives.
I order one of those double sided diamond sharpeners plates 7" 600/1200 grit for AliExpress waiting for delivery to see if it`s a waste of money.
John.
I have a few that are flexible and others that are not. I'm not sure if they are different models or different years of manufacture.Are the credit card sharpener flexible or rigid?
I'm biased, of course, but I'm quite the fan of my Arctic Fox pocket stones for field sharpening and touchups. The coarse side is aggressive enough to remove marks from even very coarse files, then the fine side gives a hazy mirror finish that easily shaves while retaining a bit of slicing aggression.
Now, if I could just get one in a full size bench stone![]()
We've got full 8x2x1 stones in production right now. Single grit, though. The surface area is too large to do them in dual grit, as the difference in shrink rate between the two sides during firing pulls them apart. Works fine on the little stones, though, as it can be better kept in check.
On a 2 part stone, Could the two parts not be fired separately and then stuck together, If there is a difference in size cut them flush once the glue has set.
John.
I edc one of those in my wallet. I've only needed to use once. To put on edge on a carpenter's hatch during a remodel job. Ive used out several other times to say I've used it. Only once did I "need" it but it's nice to know I can put an edge on a tool anytime!I use the DMT credit card sharpeners. I'm not sure how many I have but I use them at home, work, hunting, hiking, and camping. They are small enough for most kits/bags.
Ordered. Looks like a great tool!
I've got the Sharpmaker too, and just added the diamond rods. They will stay as part of my home kit with my various whetstones.A Sharpmaker is small, light weight, and works, easily. If you are just touching up there are a few key ring stones around for very quick tough ups.
You are right- the Sharpmaker is indeed a fairly compact unit, but it has a lot of individual parts that can easily fall and get lost. I want an all-in-one field sharpener with as few "moving" parts as possible.
