Nismo said:what Surfire do you all recommend to complement a pistol for defense duty?
G2Z nitrolon or Z2 combatlight?
I'm glad someone mentioned the Pelican. I wrote a review here a while back. I think the Pelican M6 LED is probably one of the best bang for the buck lights out there right now. You're looking at a bulb that won't burn out like an incandescent and the M6 LED is one of the farthest throwing LED lights. The M6 LED bulbs are also very white--especially when compared with an incandescent light and are rated (on Pelican's website) at 41 lumens for a 40 hour burntime. It has a "clickie" lockout tailswitch (click on/off) and is backed by Pelican's lifetime warranty. The fact that it uses Lithium batteries (CR123's) are both advantage and disadvantage. Disadvantage is that they're not as common and more expensive than regular alkaline batts, but the advantage is that they run longer with (I believe) a steadier discharge curve and aren't affected by temperature as much as alkalines.Sundsvall said:You should also consider the Pelican M6 Lithium and M6 LED.
There's a few minor differences--the first of which is size. The G2 is bulkier than the E2/E2e. The G2 has a lexan lens compared to the Pyrex lens on the E2e (I believe the E2 has the same Lexan lens). The difference between lenses is how well they handle heat as the Lexan lens can melt (not likely, but it does happen). The G2 also has the option of using the P61 high output lamp assembly which, according to the Surefire site, runs at 120 lumens for 20 minutes. Conversely, the E2/E2e has the option of running a low output MN02 lamp assembly rated at 25 lumens for 2.5 hours.Vess said:lolI actually just spotted G2 Surefire and thought hey! neat!
What's the difference between that and E2E anyways, besides the metal construction and lack of the clip? Looks the same from the website, same 60-lumen range output, same buttons at the back, or am I missing things?
E2E still looks awfully good to me, maybe I'll be able to get one used.
I'm glad you got some use out of my review, Sundsvall. As far as the borofloat lens, I'm assuming you already knew/know about the Borofloat and UCL lenses for the PM6/PM6 LED at FlashlightLens.com , but regarding the HAIII, you just may get your wish.Sundsvall said:I bought the Pelican M6 LED based on my impressions of the M6 Lithium and Zenghost's review of the M6 LED.
I have to say that it is almost exactly what I was looking for:
Bright (41 lumens)
No bulbs to change (LED)
Adjustable focus
Long battery life (40 hours on one set of batteries)
machined aluminum body
Lifetime guarantee
Low price
If it had been smaller, have a borafloat optic, and a Hard Anodized body then it would be perfect.
IMO this is the best deal for the money.
