Can’t go wrong with the Recon 1. Sadly, she ain’t for everyone. The tactical styling and heavy lock may put off some. If you can get past those quirks though, that’s definitely a fine long-term knife right there.Cold Steel makes good knives, some of them fabulously expensive and some of them quite reasonable.
Are you looking for belt or pocket, locking or non-locking? Have you tried the forum search function?
You also might cast a wider net in the general subforum.
Buck is always a good bet. Victorinox makes some large folders now.
I see you mentioned the S35VN. I was always curious about that steel and another just recently - pu the 6" Ti-Lite with that steel. So far so good. I always strop it after whittling and see no use of peeling away any steel by using my stones, I bring the sides perfectly together and even did a nice cold shave with just a bit of soap and my face was smooth as a babies behind. That's a fine steel to me so far and I don't see it changing shortly, is this the steel you are speaking of?The Cold Steel Recon 1 (I prefer the clip point) checks the Cold Steel, 4 inch blade, corrosion resistant (CPM S35VN blade), will last more than a few years, and is plenty sharp for everyday life.
If you want to spend a little less, the Cold Steel Large Voyager is similar, but about half the price with reasonable steel (AUS10A).
If you want to consider other makes and "almost" 4 inches of blade, you can't go wrong with a Buck 110 from the standard 420HC version to their updated CPM S30V version, or even a variety of "boutique" exclusives from vendors in S35VN, 20V, CPM154, etc.
Meant also to say - what did you mean by "lasting only a few years"? Surely not the entire knife itself...no? Or did you mean what I originally thought you meant by not having to actually sharpen it for a couple years, because that's what I see happening with mine. Response would be appreciated because you definitely got me curious. TIA. :0)I see you mentioned the S35VN. I was always curious about that steel and another just recently - pu the 6" Ti-Lite with that steel. So far so good. I always strop it after whittling and see no use of peeling away any steel by using my stones, I bring the sides perfectly together and even did a nice cold shave with just a bit of soap and my face was smooth as a babies behind. That's a fine steel to me so far and I don't see it changing shortly, is this the steel you are speaking of?
Looked it up. Seems good.If you're coming from thinner knives (traditionals and multitools), definitely consider the Spyderco Military. Awesome blade shape and ergonomics, great slicer but robust enough for hard work, and close to a Cold Steel on price.
I'll definitely keep this in mind.I think when it comes to it, price is probably one of the most important factors.
If not, just get a spyderco Millitary, any stainless steel you want. I have many large knives, but I always go back to the millitary. Its comfortable, light, robust, and smooth.
ZT452 is not bad either, if you want more bling.
Lower price range, benchmade Presidio is a really good knife. Benchmade fact if you want something tacticool.
Even cheaper, try the artisan/cjrb arroyo, agave, etc they make good smooth large folders. However my favorite is still the Civivi Praxis. The Asticus is not bad either.
Cant go wrong with a cold steel, I just find them to be overkill (especially for indoors) and not the best slicers.
Have fun shopping! I'll amend if I think of anything else.
I'm not concerned about money if it means it will be quality and last a lifetime.If you have a budget, that would help greatly. Personally, I like the cold steel recon and spyderco military a lot but there are a lot of different options out there for all flavors.
If you're not entirely sure what you want, feel free to camp out on the exchange and see if something pops up that really peaks your interest. Buying used is often a great way to save a little as most quality modern knives will last more than a lifetime for many of us, even when used daily.
Must be good steel if you can do that without killing yourself!did a nice cold shave with just a bit of soap and my face was smooth as a babies behind.
Seems good and a reasonable price.4" blade?
Cold Steel Recon series.
