Spyderco Southard has a ridiculous hollow grind. It isn’t a great cutter though.
What Banter said is so totally true. The Rectifier is such a useful blade. Also check out the Massdrop/Ferrum Forge Gent manufactured by We. Its a saber grind, but everything about this knife is amazing (including the sometimes criticized clip), the blade is a cutting machine, and it is $100. I'm always blown away by it.RIP, WE Rectifier. For a frequent user as a cutting tool (not pry or driver), that model had outstanding cutting geometry for a modern folder. Thin stock, high hollow grind, nice and thin behind the edge.
That should be brought back as a core model and kept in production, IMO. Given time, I think it could have become one of those ‘every knife guy seems to have one’ models.
^^^ This. Hollow grinds are great done right. I slice an apple every day in break room at lunch with the rest of the staff, and they were shocked at how effortlessly my Medford Praetorian T push cut thru a Granny Smith. While it's obviously well above the OP's price point, it really is a great cutter, despite the looks of the blade.Gayle Bradley 1 if you can find it. It’s miles ahead from the GB2 imo.
A thick wedge like that wil cut the apple, but also will break it as it cuts because a crisp apple is rigid the lateral pushing will push too far. Not saying it couldnt be hollow ground, but youd definitely want thinner stock. I prefer a wide flat for that type of rigid cutting material as not to crack it all apart. Next time you have a chance, cut a 1/4 inch slice with a chef knife, then the medford. You will see the medford creates cracks and "fault lines" as is cracks the apple. The flat thin blade will make a smooth glassy cut as you would want.^^^ This. Hollow grinds are great done right. I slice an apple every day in break room at lunch with the rest of the staff, and they were shocked at how effortlessly my Medford Praetorian T push cut thru a Granny Smith. While it's obviously well above the OP's price point, it really is a great cutter, despite the looks of the blade.
As I said in the post you quoted, I do this daily with whatever knife is in my pocket. And I also do it at home with a 10" chef's knife that is very thin, so I know very well what you are saying. And I am telling you that this Praetorian did a better job than many of the thin slicer's you all are familiar with. Of course the chef's knife was better at it, but it really was a surprise to me how well the Medford did.A thick wedge like that wil cut the apple, but also will break it as it cuts because a crisp apple is rigid the lateral pushing will push too far. Not saying it couldnt be hollow ground, but youd definitely want thinner stock. I prefer a wide flat for that type of rigid cutting material as not to crack it all apart. Next time you have a chance, cut a 1/4 inch slice with a chef knife, then the medford. You will see the medford creates cracks and "fault lines" as is cracks the apple. The flat thin blade will make a smooth glassy cut as you would want.
What, in your opinion, makes it miles ahead? Not disagreeing just interested.Gayle Bradley 1 if you can find it. It’s miles ahead from the GB2 imo.
