Best knife to perform an Emergency Tracheotomy
It would probably not be a good idea for any doctor to ever recomend, that someone administer a trachiotomy, for legal reason. However , in the hands of a physician or other medical professional any knife with a sharp and clean, small pen blade may be adequate enough in design to get the job done. Of course this is only if said medical professional does not have the proper equipment at hand.
A crichothyroidotomy is performed by making a vertical incision over the thyroid cartilage (forms the majority of the adam's apple), down past the cricoid cartilage(if you slide your finger down the middle of the thyroid cartilage, you will feel a soft spot and the another piece of cartilage - the softr spot is the cricoid membrane, the other cartilage is the cricoid cartilage). You then incise the cricoid membrane which lies between the two. Using the other end of the knife handle , insert the knife handle into the opeing and turn about 90 degrees to enlarge/dilate the opening - then either place an endotacheal tube, or some other tubing into the opening directed downward - give a couple of breaths & listen for breath sounds - equal breath sounds is ideal.
I wouldn't suggest anyone trying these techniques w/o training, but in a last ditch effort...
You can also place a 14 gauge angiocath percutaneously through the cricoid membrane (again directed downward) and push oxygen through it at a very high rate - can often buy you some time.
How about a Hartsfield katana? If you're gonna do it, do it with style. But seriously, I carry several knives; if I had to carry a different knife for every wierd emergency that came up, my pockets would be so loaded I wouldn't be able to walk!
