That's a really nice general use knife. I like the whittler design personally, but in general don't like D2 as a wood cutting steel because the wear resistance generally isn't beneficial and the grindability and low edge stability are drawbacks.
-Cliff
52100?
PJ Tomes utility hunter
The axe is cast D2, the folder 12C27 (IIRC)
All from PJ![]()
Not saying of course that a thick bladed knife can't mostly do even fine slicing.
I would also argue that a 1/4" thick blade on a 10" bowie is a lot less overbuilt than a 3/16" thick blade on a 4" knife and there are a lot of those which are constantly praised by people who at least present themselves as experienced outdoorsmen.
Would you really call a native in nepal using a khukuri or a guy in malyasia using a parang someone who is ignorant of proper tool selection and carries their knives because it makes them feel cool/tough.
How would you characterize someone for example who bought really cold weather gear simply because they wanted to be able to handle low probability worse case senarios. Again they are likely paying a lot more and heaving to deal with more weight/space than generally needed but does this imply they are less skilled or ignorant.
For every stance you take someone can easily move one step further. If an individual wishes to degrade those who carry 1/4" thick knives because he only needs 1/16" knives then a person who carries 1/32" blades can so degrade them. The guy who doesn't carry any knife at all because he just makes his own can then rant on about all of them.
None of this is however overly productive. It may be that someone is carrying more knife than they need because they have a rambo complex. Maybe they are operating under a false assumption because someone told them they need it. Maybe they just like knives. However, just maybe the knife is actually suited to them. Why not give those individuals the respect that would be expected of them and discuss it with them and find out.
It is easy to judge and condemn, it is harder to admit that you might be wrong and ask the other person to show you why. It is also really absurd to believe there is no chance of that happening regardless of your level of knowledge, skill or ability.
... for most cutting chores the vast majority of tactical bowies are simply ground too thick ...
I would say someone using a huge tactical bowie to slice some sausage and cheese is in about a comparable situation.
Like Cliff says though really depends on what you are doing I guess.
Is that really how you see wilderness survival as a generality?
Harder use is needed at times, other times it is not.
