- Mar 3, 2013
I'm torn between the DOC flipper, the Whaleshark, and the select fire.
Of these, I have the DOC and Select Fire.
DOC has the best features of MicroTech and Strider. It becomes smooth after a hundred open / close cycles. I can even open it via thumb studs alone. It's heavy though at over 7 ounces due to a big chunk of blade. In addition to black, you can also get them in bright colors like tan, red, green and blue. Satin blades really show off the blade shape although stonewashed and bead blasted also to some extent. If you search around you have quite a few choices in blade steel as well: Elmax, 154CM and S30V.
Select Fire is over an ounce lighter, mostly in S35VN and the blade quarter of an inch shorter. It has a long handle but feels comfortable. Mine are easy to open and close one-handed.
Between the two I prefer DOC.
I really like my Socom Elite. Very light with a big 4" blade of S35VN. The MT I use most often is my all-black Mini Matrix with a 3" blade of ATS-34. Very light and a great flipper.
The one issue on most MicroTech folders is the proprietary screws on many of them.
