Well, here's a good place to start.
http://www.brownells.com/.aspx/lid=...nic__Knowing_the_Limits_of_Rust_Preventatives
Now, oils/waxes/greases and rust prevention is a bit of a hobby for me. And I say hobby so that I don't have to acknowledge my unhealthy obsession with finding the best option. Long story short I've personally tried well around a couple dozen different rust preventatives and have read way too much on the subject.
So...onto your options. In my opinion.
1. Boeshield T9 works very well and doesn't leave a ridiculous film. If you don't wipe it off, which I don't when I'm prepping for storage, it will thicken/harden a little over the next few months and getting rid of it completely will require a degreaser and some elbow grease. I recently tried it on some bare steel tools that I left for 6 months. No rust.
2. RIG grease is what I use on my guns when storing. I have stored guns covered in RIG grease without touching them for about 6 months or so. No rust. About the same as Boeshield but instead of leaving a waxy film it leaves a greasy film. Go figure.
3. Fluid Film. This is commonly used on vehicle underbodies and that's how I found out about it. I used some to spray inside the rear fenders and rocker panels of my truck. I was told to clean and reapply once a year. So far that seems to be doing the trick. It will not harden or crack over time, or at least hasn't done so for me yet. Completely removing it will require some sort of solvent.
Honestly, I don't think you can go wrong with any of those options. I've been happy with all of them. For tools I'd probably lean towards Boeshield because the film it leaves isn't messy and doesn't get in the way of using the tool. RIG grease and especially Fluid Film can be messy. That said, they are both easier to apply. You literally just spray or wipe it on and that's it.
In general I've found waxes and greases to be superior to oil for pure rust prevention. They stay put better. If you have something with a lot of small parts or tight spots then get something you can spray so that you won't miss any spots with a wipe-on preventative.
