- Apr 12, 2009
For simpler stainless kitchen knives, an 8" diamond hone in a Fine grit can do a lot. These steels grind & sharpen easily, and even inexpensive kitchen knives aren't awfully thick-bladed, therefore not needing lots of metal removal. So, a Coarse diamond hone isn't absolutely necessary as a maintenance hone on such knives. The main advantage is the length of the hone, as longer, sweeping passes will really speed up the work. The 600 (Fine) DMT will leave a finish very similar to the Fine India anyway (and it might even be coarser), as the diamond is that much more aggressive in metal removal and will cut much more deeply for the rated grit size. And for a novice in sharpening, the feedback from a Fine/EF will be less intimidating than with a coarser diamond hone, from which the heavy, ugly scratches produced can be a confidence-killer to someone trying to learn.
With simple stainless on a diamond hone, I'd recommend it be used with some lubrication (water, water + dish soap, mineral oil, etc) to keep the hone from getting clogged. Softer stainless can do that pretty quickly, on a diamond hone.
