Generally speaking two flutes for aluminum, plastics and other "soft" materials. Four flutes for steels. For blade steels I would suggest going with carbide end mills.
If you're looking to leave a fine machine finish rather than hand finish using one endmill to rough in, and a second to finish may be a good idea.
Workholding is important for a good finish. The more stable you can lock the part down the less chatter you will get. Figuring out your speeds and feeds will also be extremely important blade steels can easily work harden which can destroy cutters and your workpiece in a flash. Running a good coolant/lubricant will help minimize this.
For specialty cutters I usually go to Harvey tools, but for general work the carbides from McMaster Carr have been fine, and they have fast shipping usually.
