- Jun 20, 2007
I am in the process of putting together a new propane forge. I used this link as guide.
http://ronreil.abana.org/design2.shtml
Here is my version and where I am at with mine. I chose a 10" pipe it is cut at 22" and capped both ends. This gives me a usable 18" x 8" forge chamber after insulation.
Also by cutting a round circle of steel and putting a foot on it that will also allow me to vary the length of the chamber being used by sliding this piece back and forth inside of the chamber.
This will allow me to use only one burner for the present time till I can see if that is going to work and if not I am already set up for the other burner.
I still have some welding to do but this will be a work rest that can be slid back and forth to support different length of steel while forging.
Both end are made so that they can be rasied for easy inspection or access if needed for longer material the rear door can be raised for longer materials if necessary. Both ends will have a suitcase type latches to hold shut while in use.
This may be my be my one screw up I was thinking to keep the minimum of 2" insulation aroung the opening I needed to cut the corners at that 45* angle, Now that I had time to reflect on this I am not sure I like it because it only leaves a flat in the bottom that should line up with my fire brick at only 2 1/4" wide. So I amseriously debating about going back and cutting the 45* pieces out and reframing the opening down square, which would leave me a flat at the bottom of the opening, lining up with my firebrick at 6'' wide.Its going to be a pain in the @$$ but I think I would like that better. If I go with a fire brick at 6" wide in the bottom it shouldn't be a problem. I am reminded of the ole ancient Chinese proverb, think twice and weld once. Or as my old boss use to say, "he had a bad case of head in the @ $$" !!!!
So here is what I am thinking I am going to start with one T-Rex burner and see how the one does with the movable divider.
I need to know !
Where is the best place to buy 6#KAO Wool?
Where to buy ITC-100HT?
Where to buy the 1" thick fire brick that is long and can be cut to use for bottom? I use to have a link for these long sheet of brick but can't find it to save my sole.
Anyone with any constructive commments and advice is welcome to chime in on this project, if it ain't constructive comments my wife has has gave me enough of those!
Oh I almost forgot I have already got my pressure regulator and valve setup and all ready to go I just havent got around to welding mounting on the forge for it yet and it won't get mounted to the last thing after painting!
I need to know !
