Best Push-knife?
I find that any significantly effective push knife is somewhat easy to replace with a 'real knife' if it's kept in a sheath/holster. So the only push knife I carry, and I carry this everywhere I go, is the tiny Cold Steel Urban Pal. It's on my key chain. I prefer to go to my Walther PPK, 1911 Springfield Champion 45, or my folder before I go to a pusher. So, it's low on my priorities.
WYK
STR,
do you use a belt or disk grinder, what rpm?
I've ground cheap indian Kukri's (they are'nt that bad really) as a kid and other blades, and they all got hot, but i was using a bench grinder and knew nothing about heat treat 15 y/a.
Tcvi. Just for you:
For the piece of steel to use for the blade. I cut that out with cut off wheels and a dremmel. Use your bare hand to hold it as you cut so you can feel when it gets warm as I said before. These wheels can be bought in a kit or a 10 pack at Lowes and I think Sears sells them also. I use the stone type for this as they are thin and produce very little heat but they cut well and fast. Just take your time and let the wheel do the work. You'll need about three to do a cut like I did off the donar blade for my push knife.
Then go to a scribe or pencil and trace out the pattern you made onto the steel.
Once you are satisfied with that go to a bench grinder and don't forget to take along your cup of cold water. Grind out the shape there using the bench grinder keeping the blade cool by frequent dipping.
Once you have your shape out you need to take off the burr from around the edge. The same cut off wheels work well for this so go back to the dremmel.
On a blade this small I use my DeWalt variable speed electric drill mounted on a Sears Craftsman Lathe. These are cheap to obtain and they actually work but I rarely use the lathe. I do however you the drill for various tasks all the time.
I used a 1.5" sanding drum with med grit to start the hollow grind on these push knife projects. Then finished grinding with a fine and eventually moved to a fine that was well used so it made the grind lines even smoother.
If your drill is one that is variable speed but only has the lock for a high speed steady rpm get you one of those quick clamps in the small size at Lowes and you can squeeze it in on the button to make the drill rpms go any speed you want. Just keep the cup of water handy and dip often. With the drill set up being reversible you can always grind so the wheel is spinning away from the edge. Just reverse the direction when you flip the blade.
I make one of these push knives in about an hour start to finish but I've probably done into the teens of them. I think the first one I did was an all morning project to get all my ducks in a row. I think its a lot of fun and you make use of something that is someone elses trash which kind of turns me on.
I get these sidewalk edger blades free at the local Rental Service Center. The guys that work there are all carrying a knife I made them using these old recycled blades. They save them for me every summer now. I must have about 6 so far this summer. Total cost in a project like this is for the sanding drums and the cut off wheels, electric power which is pennies, and labor which is hard to calculate.
The elk antler handle came free also from a natural dropping found in the woods. I use my band saw to cut a slab and my belt sander to grind it flat. 3/32 pins came from Lowes and are brass. I stictched a leather case for it also but rather like the one I made from the antler better. It is more unique.
But most people prefer the little leather ones I make. I get scraps for just a few bucks at a local saddle shop. For $10 I can get about a years worth of knife sheath supplies. Being the consumate back yard mechanic that I am I have found pretty cheap ways to feed my hobby and knife/cutlery addiction/passion by whatever means necessary. :-)
Guys,
Could you tell me where can I find a knife with similar handle as on the knife here?
http://www.angelsweapons.com/site/748984/product/C130H
I had exactly the same knife and felt it was designed very well - the handle was not symmetrical that blade was between pointing and middle fingers. Therefore you can naturally deliver the strongest punch.
However, the steel was such a rubbish that I could never sharpen it and the knife was blunt since I purchased it. And I do not like blunt knives. I could, of course, sharpen it on bench grinder, but who will buy a bench grinder to sharpen £6 knife? So, I sent it to my father and he, after sharpening, desided I had better not to have it any more. :(
After that knife I got kind of distrust to push daggers with symmetrical handle - asymmetrical handle was very comfortable that now I think symmetrical handles will be much less comfortable. Therefore I did not buy any yet. But I feel I really need one because I travel abroad quite often and anything for self-defence.
Do you think other push-dagger could be as comfortable as this one? I am thinking about Safekeeper 3 - nicely made, acceptable price, not too long blade to injure your hand and easy to conceal. But, as I said, I feel it won't be that comfortable in hand as the Chinese. Anybody to persuade that I am wrong?
Regards,
Two words for a custom push knife: Mickey Yurco. He makes one that is just killer (no pun intended), and the handle shape is more or less like the one OmegaA wants, but is much more organic.
Sincerely,
Anthony
Specifically for thrusting you can try "FGX Push Blade II", this is a cold steel blade and the name is enough to describe its high quality. They are made from grivory and stronger than zytel. I dont have this knife but I read this feature on some website under the review section who was appreciating about the design of its handle which was made from deeply checkered Kraton along with good gripping surface. Other push daggers which you may try out is FGX Push Blade I or Safe Maker I Push Dagger.
Well, what concerns me is that the Cold Steel ones are 420. Are there any custom makers that have done push knives that any of you can recommend? Are my only choices Mercworx, cold steel, and benchmade?
Umm, what are you talking about? The Cold Steel push daggers like the Safe Maker, Safe Keeper, and Best Pal lines are AUS8, not 420...
A t-handle reamer is primarily for thrusting.
As would low cost brand less triangular push dags.
Don't expect any slashing capabilities from these what so ever.
The strength is in its reinforced tips.
Perhaps they are aus-8 now ,, I don't know ,, but how about 2005 when the thread was posted ?
Zombie thread is back from the dead ,,,
1234,,,:D
