Best Set of Knives To Have In The Wilderness?
picture this: a 12-inch bowie blade with a deep recurve near the hilt, a deep belly past that, and a good upsweep of the edge towards the point. the thing has different bevel angles along these parts. the recurve is good for wittling, carving and delicate cutting. the belly is strong enough for chopping but has enough bite to slice, and the tip works as a skinner.
Such Sexy Words.
Yeah, like the Junglas is a way better version of the RTAKII? Junglas is the real deal, the other is just a crappy version of it. Trust me, they're beastly.
Thanks for the info. I'm definitely gonna buy one in the next week or two.
I agree with others that you should stop thinking about what more you need and find out how what you have works for you. True survival is often 2-3 days before you are found, so instead of having a multitude of blades, have a set amount of tasks written down, and test each knife for suitability in each area.
Because I am a knife guy I usually carry more than I need, but there is nothing wrong with that unless you are placing more faith in tools than on experience. I would suggest your bases are well covered with the Gerber (multi tool), the RAT (common use folder), the larger Fallkniven (heavier use fixed blade) and saw and chopper that you have. Once you get some dirt time with your knives you will understand YOUR strengths and weaknesses and may choose to fill those with your existing knives or branch out into new categories. If you are set on finding more knives before getting to work with them, add a $15 Cold Steel tomahawk or a CS/Tramontina/condor machete of similar value. That way you can evaluate what type of larger chopper works best with your style. Or a stockman/trapper/canoe slip joint.
When going out by myself I usually choose an axe, medium fixed blade, neck knife and slipjoint or clipped folder. But then again there is nothing wrong with buying more, just don't delude yourself into thinking that you NEED them to survive.
Yeah I definitely gotta get my hands dirty. I own a computer network cabling business and ive been working on a large project. should be done in 2 more weeks. after that, im hitting the woods. im itching to chop some wood, go fishing, and drink some beer.
Ive been thinking about getting a pocket sharpener, but the F1 and the A1 are convex edges. Wouldnt one of those Fallkniven DC3 riun the edge? I guess I can just use my belt. Not really sure. Im still new to knives.
I like immobilizing the blade with a clamp on a table. Then I use a dynamic stone (moving) and grind the knife by hand, rinse (cup of random cooking oil for the stone and a moist towel for the blade. I find it to be really easy because it was so much like grinding an axe, which I keep nice and sharp.
