Best sharpening system for novice
Sharpmaker is good - DMT aligner can get you a better edge, but the plastic is fragile and you can break the "nubs" off easily -
The Sharpmaker is good and will get a good edge but you have to start with a decent edge (I only have the standard brown and white stones) - you can't fix a really dulled edge easily with the Sharpmaker standard kit.
The DMT can be used to re-profile an edge - but you have to be gentle with it (and in reality you should be light on the touch when sharpening) -
If I could have only one I would choose the DMT Aligner and a sharpie for a novice.
I get my very best results still by hand with DMT or Lansky diamond stones - that that takes a lot of practice.
best
mqqn
The worksharp sounds like a plan. I presume however that I can sharpen seration on it? What would you guys recomend for sharpening serations?
I use a Lansky Spyder sharpener for serrations. It should cost you less than $10.
For touching up serrations and putting on a really fine edge, I have some different sized leather laces impregnated with cutting compound which I use to strop inside the serrations. At the end, you can strop the flat side on cardboard first, then on a normal flat strop.
Also, in direct response to the original question, always keep some nice pieces of stiff double or triple-wall corrugated cardboard around for stropping against. It works great for touch ups, and is very helpful for removing burrs and fine wire edges.
