- May 21, 2007
I am currently using a Harbor Freight small anvil, that probably weights 20 pounds, for peining the steel pins on Buck 110's. The problem is the pins are as hard or harder than the cheap steel in this China made anvil. So, I have a dimpled surface in the area I use for the peining and I think these dimples are occasionally causing dimples in the edges of the brass bolsters. I just figured this may be the cause of the occasional glue line not being perfectly straight.
So, can anyone recommend a very hard steel anvil that is fairly thin in the width (to fit between the bolsters on a Buck 110) and hard enough steel to pein steel pins such as the pivot pin on a Buck 110? Two to three inches wide is enough width. Cost is not a factor for me - I want the best that can be easily found/made, and shipped.
If someone makes anvil like tools - I actualy want one less than 3 inches wide with a hole somewhere in it to knock pins through if needed, and hard enough steel to not dimple when peining steel pins. 10 pounds to 20 should be plenty of mass. Again, I am willing to pay appropriately for top quality tools.
