SomeNewGuy
BANNED
- Oct 19, 2012
people around here seem to really love to suggest the para 2 even tho its nearly impossible to find a dealer that has it in stock.
Thanks for the feedback man. I'm not new to knives I just wasted a lot of time and money on cheap crap. Why would you not suggest ZDP-189? Just because of the difficult sharpening nature? If that's all it is then I'm not worried, I have decent experience with sharpening and stropping. Is there any other reason I should stay away from it?
The Matriarch isn't an EDC knife. It has one function, and that's the one you'd better be sure you're legally in the right to use it for. If I were carrying it for that purpose I'd buy an Emerson waved version and keep it tip up in my right rear pocket against the seam. Drawing it should open it and bring it up in a reverse grip. As I said, not an EDC knife though.
The Endura is a fine folding knife. VG-10 is very corrosion resistant, and takes a great edge. I'm carrying an orange one at the moment. Awesome knife and it's probably long enough to act for self defence, though I'd really rather not.
The Manix 2 looks like a fine knife with the Spyderco leaf blade similar to that in the Tenacious range. A lot of belly for slicing, sharp point. If you could swing the XL version that'd probably be ideal for your combined requirements.
The Police and Military look like upsized Enduras to me. Better steel, G10, but basically the same principle.
To be honest, I'd be inclined to buy a Matriarch and a Delica. Being small the Delica is great for EDC, and if you do need an SD knife the Matriarch looks brutally effective.
Besides a better steel, and a better lock, what's better about the Paramilitary 2 than a Police or and Endura?
how the manix 2 compared to the paramilitary?
it's made in the US also, and i'm having a hard time finding it a available to buy but how does it compare?
Gayle Bradley.
Manix2 has a CBBL (caged ball bearing lock) and the Para2 has a much simpler, but stronger, Compression lock.
Manix2 is availble with a sabre or full flat grind. Para2 is only available as a full flat grind.
Both knives have a completely different shape for both blade and handle.
I would go with Manix 2 LW. I never was fan of M2, but recently was able to handle LW model and bought it. I am very impressed. Around $70, FFG blade, choil, US made and very light. The way to go.
I've never had a problem with the screws on the japanese knives. The Endura and Police also have quad carry too.Everything.
It's made in the US.
Real .010 washers instead of the paper thin .003 washers on the Japanese knives.
The Compression lock is much stronger than a liner lock (same flat piece of spring steel, but it resists bending more because it is compressed across a shorter distance)
The pivot bushing system allows for an almost zero friction pivot with no perceptible blade play.
Full nested steel liner.
No aluminum backspacer to strip out.
Full flow through design.
Bigger screws are less likely to strip if you disassemble the knife for cleaning.
4 way pocket clip.
...All that said, good luck finding one right now. It took me months to find one in stock, now I'm looking for a spare and still having trouble. At $110 these are the best deal in knives I've ever seen.
