Best starter tool
hey guys im trying to make a few knives but i have very little money or space. so i was wondering what do you think is the one most useful power tool for knife making as i can really only get one (or two if their cheap or small enough). so what do you think wheel grinder? belt sander etc.
Ps i use the stock removal method.
Drill press or craftsman 2x42. No point in wheel grinder.
Wheel grinders are useless in a knifemaker shop. I only use the wire wheel on mine to put a semi shine on my forge finishes.
Go for the Craftsman 2x42. No doubt about it.
Drill press, no two ways about it. Files can remove metal, sandpaper can finish wood, but you just can't drill straight holes by hand.
-Xander
First tool - A pencil and pad of paper....
then a drill press....
then an entry level grinder.
Files and sandpaper are required for any knifemaking.
+1 for the drill press. But an angle grinder to rough cut bar would be #2 for me. Clamps and a vice for non power shop items. You can never have enough good clamps.
Drill press for certain. An angle grinder is sort of optional, but they're so inexpensive ($20-30 as I recall - mine was a gift so I'm not sure) and handy, I'd say go for it. Plenty of quality files and drill bits... don't buy a set of 50 sizes, just pick 3-4 sizes you'll use most and buy doubles of them. Stick with 1/8" or less stock and you can clean up profiles and cut bevels with a file almost as fast as with a grinder.
yeah, that was my thought on the angle grinder $15-30 will do ya for knife work for a long time. My cheapo Harbor Freight is working fine. Drill bits are not as obvious as it seems, since most pins are too big for the "matching" drill bit. My usuals are 1/8" and the matching reamer, 7/32 bit, 5/32 bit and 3/16 reamer, 1/4" and matching reamer. The reason for the group in the middle is because I'll oversize the 3/16" pin holes in the steel most of the time but want to give the reamer an undersized hole in the handle material. I was finding that the 3/16" in particular tended to wind up giving me issues otherwise. The 1/8" tends to drill cleanly and so does the 1/4" so I rarely bother with the slightly undersize bit. Obviously everyone's got different needs since we all do handles a bit differently and have different equipment. It's just something to keep in mind. When you order pin stock from most places and it's 3/16" stock, it will NOT fit nicely through the hole a normal 3/16" bit makes.
Remember to get cobalt bits for any you will use on steel.
Perhaps you could be more explicit with us.............. You say very little money and space. Could you be more exact? How much, or little, $$$ and space are we talking about?
For example, drill presses are dandy things but I wouldn't want to have one in my bedroom so if you don't have a space where you don't mind metal chips flying around the room I'd be thinking hard before springing for any toolsl. That makes me think about portability and I'd say you might be looking at a 1/2" electric hand drill. These can be had very cheaply and there are a myriad of accessories including holders that will turn it into a drill press! You can use one to drill holes, polish, cut (very carefully with an abrasive cut off wheel ), the list could go on for days............... Of course those accessories cost too. I'd be checking out Craig'sList, eBay, garage/estate sales, auctions etc for tools on the cheap myself. Once you start acquiring tools you'll never stop, take it from me. As your collection grows you'll need to store them and maintain them. You 'll want a workbench and a vise soon too. I could go on but you get the idea...................
You could practice on wood to start too to get a feel for the way it works. The 6H pencil that Ron Lake mentions in his book on folding knives, along with a good 6" steel rule and some graph paper couldn't hurt either. Then there's the library where you might be able to check out some books to dig into. Those don't take much space and costs nothing........... The $50 Knife Shop by Wayne Goddard might be the best place to start now that I think of it.
Tell us more and you might get some surprises
Good luck regardless
Syn
The Dewalt 4 1/2 inch angle grinders can be had for 49.95 at present; they are a quality tool. There are many uses for one in the knife shop. Profiling, surface prep on steel and even bevel grinding if you have a steady hand.
Drill press a must.
You can get a small table top drill press for $100 and a sears grinder for $140 and your set.
