Thank you for your help and suggestions. I will try to locate some of the suggested steels.203E is a high nickel steel with very low carbon. It works excellent for ornamental damascus. Use a lower carbon steel at the dark portion. You could probably do fine with 1045.
It should work with WI, as neither need hardening.
I am looking forward to trying this as soon as I can source the 203e. Probably tomorrow morning I will make some calls.203E and O-1/1084/1075 (any one of these) would work well.
What steels are you thinking of when you say “cheapest options that would etch…”? I am not familiar with Gunkote enamel and will do some research. One of the requested items I have had is for shifter handles. So that would get lots of wear.If I were going to be doing alot of non-tool pattern welding where the contrast/how it looks is the only concern, I'd look for the cheapest options that would etch to topography, and then use black then clear Gunkote bake on enamels.
I had nothing specific in mind, but if you go the GunKote route, you don't need to harden the steel in order to get the pattern/contrast because it's painted (I'm thinking about experimenting with colored damascus), so I would think mild steel and a nickel steel like the 203 mentioned above might be cheaper than using knife steel. If it welds to mild steel, that is.What steels are you thinking of when you say “cheapest options that would etch…”?
This is basically what the GunKote method is/does. You use an airbrush to apply the black paint, then bake it for 1 hr at 300F. When cool, sand the piece with 2000grit paper (or so) to polish off the 'peaks' leaving the 'valleys' black. I follow up with a 2nd coat of clear. But to try to answer your question, I'm not sure what you mean by "protracted" etch, but the stronger the acid, the quicker the etch, so... yes?to be filled with something like black epoxy
Do you have a pic of this finish? I'm having a hard time imagining it looking good. Maybe it's just because of the time I put black epoxy in some jimping.This is basically what the GunKote method is/does. You use an airbrush to apply the black paint, then bake it for 1 hr at 300F. When cool, sand the piece with 2000grit paper (or so) to polish off the 'peaks' leaving the 'valleys' black. I follow up with a 2nd coat of clear. But to try to answer your question, I'm not sure what you mean by "protracted" etch, but the stronger the acid, the quicker the etch, so... yes?
Wow, carry on then!
