I'm looking for your opinion:
As part of a residency for graduate school, we are headed up into the mountains. After signing all the AD&D waivers, we are allowed to bring one folding knife. No lodges, no cell phone coverage, no Leathermans, no guns, no fixed blades. Animals: bear, mountain lions, wolves, coyote, fox, etc. What is the FOLDER YOU would take and why? I'll be up in the Uintas for a week.
Spyderco Tuff is a solid secondary tool; the 3V steel would handle whatever
I'd throw at it.
I dont own one but the post about the bm adamus made me curious so I looked it up on youtube there's a video of some russian dude beating the hell out of his adamus. Pretty impressive
And did you see where they test the lock strength, to around 1600 pounds? Where liner only went to 170 pounds, and smaller type axis locks to 660 or something.
And people who suggested manix are crazy. You tube thesetwo videos please
Griptillian hard use test
SpyderCo manix hard use.
And while you at it >> Breaking the benchmade griptillian. (I think it's that)
Sorry to say, but if it's not axis, you will break your knife.
Not too experienced on compression locks however. But in theory it should also be very very strong like axis
Anyone had a compression lock fail? Or info on the matter
Its always possible to find dry wood for a fire, the internal side of the branches is in fact enough dry also if the external part is pretty wet.
It is possible to arrive at the internal side of a big branch also with an humble Victorinox 91 mm, as the Farmer
Lets see how. First, I saw the branch until the middle (not more)
Now, with the sawed side external, hit the branch against a tree
After a couple hitting, the branch began to split
Again a couple of hitting, and its done
Anyway, for afire I need to split again the log, so I cut another piece of wood from the branch
I now had two pieces of wood
I wok one of them, I want to obtain a sort of nog
Now, I use the blade of my Farmer to baton, carefully, the log that I want to split, to made a split
Using the nog, I baton until I split the log
Note that my Victorinox Farmer is still in perfect shape, using it to split the big branch but in a smart way
Now I found the dry part of the branch, so I may cut long and thin feathers
And I had the fire
Conclusions: a fire in the woods is always possible, is great having a good fixed blade, but you may making fire also using a small multitool knowing the proper techniques.
Ciao,
Alfredo
You obviously haven't been chopping or abusing your knife as the subject predicts. Get nasty with them and you might as well throw them away. . . Use it as a normal knife then cool. But knowing youhave overbuilt knife in the wilderness is much better advice then suggesting a knife that will collapse after he does his first wood shavings for a fire. ..
Can't argue facts my man. . . Might as well go to war with a 9k ppk then. You'll be great...
Besides a SAK Trekker, considering your requirements, I second someone's suggestion with one of the large to extra-large Cold Steels. Furthermore it has all of the three features below to supplement your needs -
1. CHEAP enough so as not to make you too upset should you lose/break it in the sticks.
2. STURDY and capable enough to be used heavily (er, I'd use "STRONG" for fixed blades!).
3. BIG enough for your hands and to accomplish a variety of tasks (if you are going to use them heavily for long periods, a FULL ENOUGH grip will be a God-send).
4. Oh yeah, costs CHEAP (see #1).
Anything with decent stainless steel and a solid lock would serve quite well.
Seems like rust resistance and edge retention should be your primary concern.
