You mean like this: http://www.swampratknifeworks.com/blog/axe-hammer-matt-axelson-tibrute-knife/Fällkniven A1.
I had a Randall #14 in stainless stolen from me some years ago. I need a really good custom or production survival knife, really tough. Not sure if I would go the stainless route again. I know there will be quite a few opinions
Thankfully I have not been in any survival situations. Sadly, I did not have the knife very long before it was stolen.
Frankly, after it was stolen, I became very busy and took a hiatus from collecting knives and did not bother to replace the Randall.
I am semi-retired. For a number of reasons which are not relevant, my wife and I have become more acutely concerned about being prepared to quote the old boy scout motto. A survival knife is just one of many items on our list.
@Everyone. I purchased my Randall #14 in stainless back in the min 90s. A lot has changed in the metallurgy of knifes since that time. That is why I am posing this question. In a true survival situation, something that we certainly do not encounter in our regular day to day lives, one would want a knife that is multi-purpose, holds an edge, and is tough enough for batoning....,at least that is my thinking.
When I ordered my Randall I had a hard time deciding whether to get it in stainless or not. It certainly was not so easy for me to sharpen when I actually tried with various rocks...(it was a test...not the thing a Randall collector would want to do.)
The truth is, I hope I never have to use any knife in a survival situation.
The pre-order for the Carothers is closed.
Cost is not a consideration. I am not interested in collecting survival knives. I just want a really good dependable one. I don't expect bells and whistles that will allow it to morph into a machete by pouring water on it.
What I like about this Forum is that fact that there are many opinions about any given subject. That said, shopping on Amazon can be problematic even when an item has 4.8 stars because there are always going to be people that have a bad experience with any given product. The truth is we have so many options to choose from it is sometimes difficult to choose.
Since a knife is just one of the many items on the list, why does it have to be a big survival type knife that tries to do it all. Often times a knife is either going to be to big to do fine tasks very well or too small to chop. A good hatchet ( a Vaughn riggers axe is a good option as it has an actual hammer to use in a survival situation) and a smaller knife which could easily just be whatever folder you carry daily will handle most survival tasks.Thankfully I have not been in any survival situations. Sadly, I did not have the knife very long before it was stolen.
Since you have already experienced a Randall and liked it, I would advise a Randall Model 12 with a 14 style grind, with a mildly finger grooved handle (The stag handle is quite commonly seen, but stag is less reliable than micarta or leather washers). Avoid the horrible "Commando handle", which needs to be ground down by half (like mine) to be even useable...
The advantage of the Model 12 over most contenders is it has a proper stick tang which saves weight in the right place, instead of burdening the knife with hugely heavy full-profile metal "fat". It also isolates the hand from vibrations which is another bonus. Third advantage: The blade itself has a proper hollow grind that is extremely effective and allows it to out-chop most other knives in this class, while still allowing for fine slicing work, a truly rare combination. Hollow grinds generally allow near-identical chopping performance with low effort lazy swings.
Contrary to what is usually said, a saber hollow grind also takes unintended lateral loads off the edge, preventing "twisting chips", although here the saber grind is so high this doesn't play to much effect...: Instead, Randall gave the Model 12's edge a slight "swell" just above the V-edge, which has the exact same effect, at near zero cost in slicing performance ...
Finally fourth advantage, and not the least, the Model 12 is available in excellent 440 stainless that is practically the only one around to be forged, Randall being just about the only ones who forge stainless...
Here is how my Randall Model 12 performed against a San Mai III Trailmaster with a full convex edge:
Here is how my 5 ounces lighter (14 vs 19) and 1.4 inch shorter Randall Model 14 performed in comparison to the 12...: The deep finger grooves feel wonderful for light tasks, but are horrible for any heavier use...:
The Model 12 is a far better knife, and seems more precisely ground from what I have seen. I would avoid batoning as the wood grain's changing direction inevitably causes tiny apex micro-rolls (detectable with nail rubbing only), not to mention cold weather can easily cause an unpreditable failure... I would also avoid Carbon steels like the plague, if only for sanitary reasons, unless you know it will never rain... Keep in mind Carbon is considered unsanitary for today's professional kitchens, so don't fall for nostalgia...
Gaston
Survival knife is now an established class of build over a general purpose knife. Be it folder or fixed they are built a bit stronger to ensure they don't fail. This extra build loses some practicability over a thinner more refined blade.
The "one tool option" has been spouted about since Rambo days. One ring to do rule them all! One blade that can chop like an axe and cut like a paring knife. Sadly, they end up poor at both. Either too big and bulky for any real dexterity, or too small without enough heft to compete with an axe. Forget the "one tool option"; its fun but rubbish in practice. The big ones end up left at base camp which might be back at home 500 miles away.
The knife you will have on you in any survival scenario will be the knife you are most comfortable carrying as an EDC or pack in your pack. Carry a few cutting tools, each good in each category. A fine thin cutting pocket knife for all those small tasks. A general purpose fixed blade for belt carry. And a chopper be it axe, golok or machete. Always a Silky Saw in the woods for pure efficiency. If you lose one you still have the others.
If you feel that a slightly heavy duty build is required then fair enough. Probably more importantly is the type of steel and heat treatment. A survival knife shouldn't break. It can go blunt but mustn't snap. It mustn't lose its integrity as a knife. Here thickness or cost in no guarantee. Quality of build to be tough is. Which one has been built right or has "the luck" built in is pretty tricky to know. Use a blade for a while and thats the best test. every new knife is a gamble until its gone through the paces; just might not have any luck in it.
I like what Survive Knives do. I like what Esee does. I like Chris Reeve Knives. I like a 4" to 5" fixed, built to be a little bit tougher than my hunting knives, as my general purpose survival knife. What ofter that is a fit and feel, and confidence thing. There are plenty of knives up to the task.
If its too bulky, too heavy, or even too expensive, it will end up back at home rarely used.
Having just turned 65, survived growing up in the streets of NYC, a number of other questionable places, situations, and being in the wrong place at the wrong time in the path of a .45 cal slug, I think I can handle most anything.Hey Andrew ! I suggest you read through the recent post by " TheRiggins" , titled " Looking for a good survival knife "
. Your specific knife selection is much less important than the knowledge and skill to actually use it to survive and your overall survival strategy .
Just as in self-defense , 90+ % of success is in avoiding dangerous situations
. Once you become committed to serious survivalism ( now called "prepping" I believe ) it is a lifestyle . Much short of that and you're just fooling yourself . And there are practical limits to what is survivable at all . Very deep topic and you didn't ask for all this blather , anyway .
I am hoping to live out the rest of my days without having to grab a bugout bag. That said, the last 35 plus years in the DC environs has filled my brain with information I would rather not know. Bad things may be coming down the pike.
In the ideal situation I would never consider relying on one of anything. A knife is not going to do what an axe does better just as I don't plan on using an axe to slice vegetables. Hopefully we can make it to our "safe" place where what we need has already been stashed. However, if not, and among other things, I have to grab one fixed blade knife....that is what I am trying to figure out.
