Best way to check temperature?
I am using a little fire brick forge and would like to know what the best way is to check the temperature? Thermocouple, laser-thing, etc, what do you guys think? Is there an analog thermometer that goes that high?
I use a $3 thermocouple from eBay and a $9 digital multimeter. Most multimeters will read high enough, but are a couple degrees off over 1800° F. Make sure you get a thermocouple with at least 3' of metal wrapped cord. You'll have to cut and splice a little, but you should be able to make it work for a lot less than the expensive ones.
Look for an Omega handheld digital K type thermocouple thermometer with an 18" probe.
They are surprisingly inexpensive ($150-$250) for an industrial tool that measures from -320 to 2500*F within 1* accuracy.
I use it to keep track of how slowly I'm cooling blades in a LN tank, and minutes later I'm checking forge temp.
Easily one of my most indispensable tools.
I'll have to add this to my bag of tools!! thanks for the tips guys!
You might wish to read the specs on those SS type TC - usually it's 400ºC or less. Since this is for forge work you'll need something in the 2,000 ºF range. Take a look at this TC with ceramic covering:
http://www.auberins.com/index.php?main_page=product_info&cPath=20_3&products_id=39
You can read the output in mV on a DVM, OR, many DVMs have a degree scale that reads type K TC.
Auber also has a complete package here: http://www.auberins.com/index.php?main_page=product_info&cPath=17&products_id=199
You will need to select the sensor that has the ceramic covering, AND you might wish the 8 AWG TC rather than the 11 AWG TC if you plan LOTS of time in the forge.
Ken H>
For reading the air temp , a roast in the oven, or your hot tub, most any type TC will work.
For reading forge temps and knifemaking work, a robust type K TC is needed. You need an 8-10 gauge probe ( 1/8") with leads long enough to get away from the heat source. If permanently mounting in a forge, use a ceramic sheath.
The reader can be a multimeter, pyrometer, or a PID. The accuracy varies greatly, so look closely at the accuracy and range. Some say things like "+/- 3 degrees...or 3%". At 1500F, that is +/- 45 degrees. That is close enough for many things, but not really good for HT.
Take several readings and average them for the best results.
Use a TC block to connect the TC leads to the wires going to the reader, and observe polarity. You must use TC wire that matches the TC ( type K). Regular speaker or lamp wire is the wrong type, and will make the reading inaccurate. Best method is to use a TC plug and cord that fits the reader device, or install one and use it. The plugs are polarized, and the wires are correct.
