- Feb 17, 2003
Many of them also have a VERY highly reflective surface. Excellent for shining the sun into people's eyes at long distance.ErikD said:Yeah, sorry Gollnick you are off base a bit here. The actual media inside a HD is about an 1/16" metallic plate. Think of basically a CD made out of some sort of metal and you get the idea, no knife will cut it easily.
Gollnick said:It is not necessary to use shotguns, electromagnets, brandy, or anything exotic. Once you take the screws out of the hard-drive's outer shell, you'll find that the media itself is thin, flexible piece of brown/black plastic that can be cut to shreads with a knife in seconds. Once you cut it into a few pieces, it would take the NSA to put humpty back together again... and we're going to assume that the value of your information doesn't rise to that level.
Gollnick said:I may be remembering wrong. It's been a long time since I actually tore one apart myself. If it's a rigid disk, all the better. Just shatter it.
Revolvergeek said:"At best buy at the tech bench they drill holes in the hard drive. the platters won't spin correctly." This is a fast solution for them, and makes the customer happy, but not the best solution at all. Most of the data is still there and many good forensics labs could still salvage a lot of it .
Johnclarke said:I have used my 1911 on bad drives and the several well placed rounds will pretty much mess up the platters so much that I dont think anyone will get data from them.
