I have a quick question. When you grind bevels on say a drop point hunter, do you pull the blade straight across from the plunge lines to the tip. Or do you start off straight and then follow the curve of the blade. The reason I ask is because on the picture below ( the third knife I’ve ever ground) I followed the curve of the blade. I was wandering how people pull straight across the a jig and get the same result. Am I wasting effort trying to bend my whole body as I get to the curve? Also I use a bubble jig and plunge jig until I’m about 50% there the. Swap to freehand. Don’t know if that helps. And somehow I lost the very tip of my knife. Still not sure exactly how that happened. Any advice is welcome and thank you in advance! I have plenty to learn.
