- Mar 2, 2017
https://imgur.com/a/Y0LwO
What is cause the wavy bevel. I am going slow steady and applying equal pressure
Even with the jig?You will NOT I repeat Not create good grind lines if this is for first or probably 10th time trying. Get some mild steel at the local hardware and a bunch of 60 grit belts to practice with !
Frank
Send me pic of the surface grinderJigs are something a lot of new guys look to ....I did when I was new a few years back....BUT jigs are limited you are much better off going to get a bunch of cheap mild steel like frank suggested....eventually a lot of it becomes muscle memory just like riding a bike. When I started I wasted a bunch of time with various different jigs and all I found out is that a lot of things can only be done freehand...just takes practice. Also the flatness of the steel is also key. when I learned freehand even if the steel wasn't flat eventually I learned how to compensate for that and even things out....eventually I got a surface grinder. Not for this purpose but it actually REALLY surprised me of HOW UN FLAT the steel was. I thought it was at least close to perfect....nope not even close (unless what you buy is PERCISION ground) I started cleaning up blanks on the surface grinder before doing the bevels and it sped things up ALOT because now I did have to compensate and even things out constantly.....in short learn freehand is number 1 number 2 is get flat steel or learn to even things out by hand as you go
1. How do i flatten the billet.
