- Mar 2, 2017
How is this for a hand done bevel. 120 grit. https://imgur.com/MtLikKu
Okay, so I'm not staying steady in the second pic? Thank youassuming the steel is flat and parallel and the edge thickness is consistent from ricasso to tip
In the first pic you are grinding a constant angle. A constant angle from one end to the other will follow the edge like that one does (roughly speaking, the bevel is rounded where the edge has a sharp bend, likely the edge is a bit thick at that bend).
In the second pic you have ground a variable bevel angle. The bevel is straight from one end to the other. This happens when you grind a steeper angle at the narrowing tip than the angle you started at the ricasso.
If the top assumptions aren't true, then the cause becomes harder to diagnose from those two pictures. If the steel is warped slightly and the edge is consistent thickness, then the top of the bevel will invariably change.
So to follow the curve, do i maintain same angle and pull away from the platten as I get close to the tip
