BF Blue Native Clip Question
Now that I've received my Blue Native, I've run into a slight problem. The clip's screw is so tight I can't move the clip to the other side. I know I could probably get it loose with a couple of screw drivers, but I really don't want to scratch the screws up. Usually, a pair of pennies works on Spyderco's, but not this time.
Any suggestions?
Ray
Knowledge without understanding is knowledge wasted.
Understanding without knowledge is a rare gift - but not an impossibility.
For the impossible is always possible through faith. - Bathroom graffiti, gas station, Grey, TN, Dec, 1988
AKTI Member #A000831
Codeman, I had the same problem with my BF Native. What is happening is that one side of the clip screw fits firmly into the G10 scales. What I did was to take a quarter and clamp it in a vise-grip or grab it with a pair of pliers. Then try to loosen the screw from the clip side. When you get the screw loose, then you will need to hold the screw from the other side to remove it completely. The quarter is a softer metal than the stainless steel screw so you don't have to worry about damaging the clip screw.
Dale Richmond
AKTI Membership Pending
Man, the screw on mine was so tight I chewed up four nickels, two quarters and a penny trying to get it loose. Gripping the the coins with a pair of pliers didn't help. Then I tried a screwdriver. The screw heads on both sides are slightly blemished, and I chipped a bit of the blue stuff off of the clip. But I managed to get it loose finally. Then you know what happened? The very next day somebody posted a question about the tight clip screw problem, and Danelle suggested WD40. Dang, why didn't I think of that?
David Rock, Ph.D.
Retired Smart Guy
AKTI Member # A000846
"Never carry a knife shorter than your schnoz."
