Okay this last part about hollow grinds being weaker is totally misleading, maybe even flat out wrong. There are so many other variables that are involved with strength issues, that the point is moot. I can think of only 2 makers that put their knives under "extreme conditions" during shows, and both were hollow grind knives. One maker hacked apart steel table legs (Strider) and the other cut apart one of those big oil drums (MMHW). I don't think I need to go into all the elements that make a knife strong, but I know a few very well respected makers who would take issue with your comments on grind strength.
The original discussion about chopping boils down to this: Cliff says that the wedge created by the grind is what effectively splits the material. With this argument, hollow grinds impede chopping because the back of the grinds wedge into the material. I think that, since the edge is doing the splitting, any material on the sides of the knife is going to create resistance, and thus impede chopping.
Cliff talks about flexibility of the material being an issue; the material doesn't move in straight lines to either side of the blade. With my opinion of the nature of chopping, this would make hollow grinds work better; because the material has more distance to travel laterally to make contact with the blade. Because of the nature of the edge angle, by the time the material passes by the start of the grind, it generally is fairly far from the blade.
I have in front of me a Mineral Mountain camp bowie in flat grind. Ted has been offering flat grind blades for about 6 months now. It will not chop as well as its brother in hollow grind (and it certainly will not slice as well). Period.
Several years ago I started noticing that the MMHW I owned seemed to perform better than other (flat grind) knives I owned, but it wasn't until Ted started flat grinding that it was possible to actually test grind VS grind. This is because there are SO many other variables involved with performance (edge, geometry, thickness, steel, etc.
As far as I'm concerned, all of the "scientific" style analysis in this thread is a waste of time; Cliff is much better at it than me, but it is fuzzy logic at best- for both of us. Semantic masturbation. In this matter,
Truth is based only on experience and real world feedback, not pretend-scientific jaw-flapping. The thoughts I've expressed in regards to the explanation of how each grind works/doesn't work are speculation; speculation derived out of an effort to explain my and other users' experiences.
And I am SO out of my league with Cliff in this debate. I simply do not have the capability to argue with him, so this is going to be my last post here (unless I feel particularly masochistic
). As always, I look forward to reading what you have to say, Cliff, but my mind won't be changed unless my experience somehow changes. I hope other readers will consider the same method of "reason via experience".
Later!
